Extra part! Where does it GO!!!????
Old Jul 1, 2007 | 12:08 PM
1998LS1SS's Avatar
Default Extra part! Where does it GO!!!????
I just changed my front springs and painted everything black. Driver side was good, i think, but when i was finishing the passenger side i found this little rubber thing. WHere does it go. Do i HAVE to put it back in? I really hope i dont have to compress my shock again. I HATED it SO MUCH!!!! Thanks.
Old Jul 1, 2007 | 12:23 PM
boondiggys's Avatar
that is a dust boot that goes between the top control arm bracket and the vehical when bolting the strut into the car.
Old Jul 1, 2007 | 12:52 PM
1998LS1SS's Avatar
will there be a side effect if i dont put it on?
Old Jul 1, 2007 | 05:14 PM
Krab's Avatar
Yep, that's the part that goes right under the shock nut. I'm not exactly sure what affect it will have on your suspension, but I'd be tearing it down again if it were my car.
Old Jul 1, 2007 | 09:31 PM
96silverram's Avatar
I think your going to have to put that item back in the strut tower assembly. I believe that is the rubber isolator for the top of strut.
Old Jul 2, 2007 | 11:50 AM
1998LS1SS's Avatar
Yep...it went right were that bolt that holds the spring on the shot and goes between the shock and the body...took it off and slapped it on...i was scared i had to compress the spring again...its a b#%@...Thanks
Old Jul 2, 2007 | 03:27 PM
l337_haxs's Avatar
I forgot that piece when I changed em on my old 95 and it blew the shocks top right throught the mount. Put it on and it worked fine after that!
Old Jul 2, 2007 | 07:14 PM
GTObsessor's Avatar
Heh i made the same mistake on mine... easy to get it back up in there.
