bleeding brakes
Old Jul 4, 2007 | 05:48 PM
Disturbed Bird's Avatar
Default bleeding brakes
whats the propper way to bleed the brake system?
Old Jul 4, 2007 | 06:19 PM
koolaid_kid's Avatar
To let all the air out and keep fluid in.
I'm just joking. Could you be a bit more explicit, please? Do you need everything from step one, or just the fact that you start with the brake farthest from the master cylinder, right rear. Then left rear, then right front, and end up at left front.
If you need everything, I am sure there is a Tech article that will tell you start to finish that we could point you to.
Also, we need to know which car it is, the Camaro or the WS6, do you have ABS, traction control, etc.
Old Jul 4, 2007 | 06:59 PM
thats pretty much what i needed i have abs on both and its for the t/a and no traction control on either
Old Jul 4, 2007 | 07:15 PM
wannafbody's Avatar
I read that the Helms manual says to start with the LR, LF, RF, RR.
Old Jul 4, 2007 | 07:39 PM
I suggest that you disregard that information. It has always been farthest first, then next farthest, etc. And my Haynes agrees with me.
It's even that way for my motorcycle with antidive front forks, farthest to closest.
But I am glad you made me look; you have to bleed the ABS modulator first, which was why I asked the question. Let me see if I can find a procedure; I'll post a link.
Old Jul 4, 2007 | 07:47 PM
Can't find an article, but that is the order: ABS, RR, LR, RF, LF.
Old Jul 4, 2007 | 09:41 PM
how do u bleed the abs?
Old Jul 9, 2007 | 02:46 AM
bison160's Avatar
yes, I would like to know this too? If anyone knows or could do a complete write up of the complete procedure from start to finish that would be great.
Old Jul 9, 2007 | 08:35 PM
its pretty easy. this is what i did
remove rubber hose and install the ss line above the rear.
remove rubber hose and install back passanger side ss line then bleed that one only.
remove rubber hose and install back driver side ss line and bleed that only.
remove rubber hose and install front passanger side ss line than bleed that only.
remove rubber hose and install front driver side and ss line bleed that one only.
vary easy took 2 hours all together. and i dont have traction control
Old Jul 10, 2007 | 10:53 PM
HavATampa's Avatar
Remove and install? Remove what? Install what?
remove and install the middle rubber line above the rear.
remove and install back passanger side then bleed that one only.
remove and install back driver side and bleed that only.
remove and install front passanger side than bleed that only.
remove and install front driver side and bleed that one only.
Old Jul 10, 2007 | 11:51 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I'm wondering about the ABS system also. How do you bleed this? I'd like to get this done properly as I bled everything but that and my BRAKE light won't turn off. Granted my car isn't going anywhere under it's own power any time soon.
Old Jul 11, 2007 | 03:08 AM
lt1 car u can bleed it seperatly but on ls1 car you dont and cant
fixed
Old Jul 11, 2007 | 05:10 AM
JEB99TA's Avatar
... been awhile since I've bled my brakes, but, I always just have somebody pump the pedal and hold it to the floor (with the cap off the reservoir) while I loosen the bleeder nuts and re-tighten them. Is it different on a F-Body?
Old Jul 11, 2007 | 01:20 PM
teke184's Avatar
ok...so what happens if you have Traction control?
and is it me or has nobody said how to bleed the ABS
Old Jul 11, 2007 | 01:35 PM
z28bryan's Avatar
You can't truely bleed the ABS on the LS1. You need to take it to the dealer for that. FWIW, I didn't bleed my ABS and my brakes have felt much better on a normal brake bleed alone and this is on the autox course.
The guy above mentioning to "remove and install" I'm pretty sure is referring to installing steel braided brake lines, which you don't need to do.
I kind of don't blame you for wondering how to really bleed the brakes. There's info online about it, but not exact info on what each single step is. I had to play around with it to figure out what I was doing, but maybe this helps:
1. Siphon old fluid out of reservior
2. Fill reservior with new fluid
3. Have someone who is patient sit in driver seat
4. Starting at rear passenger side, get hose and bottle assembly set up on bleeder screw
5. Command person at driver seat to start pushing brake pedal and immediately turn bleeder screw 1/2 turn
6. Have driver tell you when pedal is all the way down, and then close screw
7. Tell them screw is closed, and then driver releases pedal now, driver tells you when pedal is all the way back
8. Repeat steps 5-7 until all air bubbles are gone and only clean fluid comes through tube.
9. Every once in a while check reservior because fluid will go down. Make sure its filled, and that the cap is closed when you are bleeding.
9. Do the same thing at rear driver, front passenger, and front driver.
This is the ghetto old school way of doing it. There are solo bleeders available, but I've heard they aren't perfect and sometimes leak air into the system. If you have any siezed bleeder screws and completely strip them like I did, buying replacement calipers is affordable from Autozone, just 40 bucks per caliper.
Old Jul 11, 2007 | 01:44 PM
z28bryan's Avatar
If you wanted to bleed the ABS or at least get some of the old fluid out of there, then you could do a full fluid flush first. Then take the car on the street and hit the brakes to engage the ABS system fully. Then do a full fluid flush again to get whatever was in the ABS which would now be somewhat distributed in the lines. It's not perfect but it is costs less than bringing it to the dealer to have done with their machine.
Again, I didn't even do this and my brakes are working pretty damn well.
Old Jul 11, 2007 | 02:25 PM
Da Swami's Avatar
And it didn't set off your ABS light?
Old Jul 11, 2007 | 02:34 PM
z28bryan's Avatar
Are you asking me that? No I didn't get an ABS light. Did you? I only get the low trac light when the ABS is engaged.
Old Jul 11, 2007 | 05:28 PM
i didnt get either but the reason i had the ss lines in that is b/c i went from rubber to ss lines and bled them normaly. perfect again and alot firmer feel
