SLP LineLock installed, now i have a mushy brake pedle
i just installed my slp linelock, and now my brake pedle feels like it grabs about 1.5-2.0in lower than b4, i bled and re-bled already, the car stops fine, the linelock works, just seemed wierd how the brakes feel now, is this normal???
Is this normal?
No, there must be a leak / air in the system - I had to bleed the system three times then after 20 miles of driving I noticed a drop of brake fluid on the bottom of the solenoid; I had to tighten up the fittings on the top and bottom of the solenoid and bleed the system again - problem solved.
In between bleeds, turn the car on for 30 seconds to make sure the ABS unit test itself by cycling. This may help work out the air.
Check those fittings on the line lock religiously. I had to work on them 3 times duting install to stop all the leaks. I still check it every time I open the hood just to be safe.
i found that it leaks just a bit, i tightened them up some more,
ull think i can use thread tape on the fittings or some locktite??
