UMI K member
or K member and upper and lower A arms
My goal is weight off the front end. and Im getting the road race K member, because I will occasionally take it road racing and I drive teh car pretty hard even on street. Its a DD and will have a head/cam soon pushing over 430RWHP....
I know I already want the K member.
But is it worth getting A arms, and if so, upper and lower? or is stock just fine?
because the way I see it, im not really saving too much weight with the aftermarket ones.... and are the stock ones flimsy and should be replaced?
i would replace the upper and lowers as well. why only upgrade half the front sus and leave the other old/ beat stuff in there.
also go to the auto parts store and get new upper ball joints for the new upper a arms they were 35 bucks ea.
the uppers/lowers are gonna def be better then stock who cares if they are a lb heavier. i lost 28lbs in the swap. youll lose about 25lbs since the RR Kmember is 3lbs heavier
heres my install that i did last week. it should help you out.
https://ls1tech.com/forums/suspension-brakes/763317-umi-kmember-arms-install-guide.html
-brandon
-brandon
Are the upper and lower control arms lighter than stock components? If not, I'd probably just get them to have the camber adjustment. The kmember would lighten the front end and make room for easier access underneath. Just make sure the kmember you get can handle racing.
Are there any other reasons for getting different upper and lower front control arms? I dont see how the metal portion of them would be flimsy, except maybe the rubber bushings.
Originally Posted by LSGunZ28
So over all what will my weight savings be?
Its a lot for the damn whole set
1300 bucks!
1300 bucks!
its def worth it IMHO.
dont forget to do other weight mods as well, like raceweight battery abs delete, ditch the cruise control etc.
-brandon
Originally Posted by Demonicbird00
id say about 25-30.
-brandon
-brandon
cruise control, not yet
but raceweight battery sounds good.
where can I get this.
what #s will I be looking at
like cca .
Originally Posted by z28bryan
Your not going to have anything stock left on that car ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
