Check this coil spring compressor
Old Oct 9, 2007 | 10:02 PM
sdiddy's Avatar
Default Check this coil spring compressor
http://www.harborfreight.com/cpi/cta...temnumber=3980
Is this thing worth trying out?
I finished the rear shocks/springs and am going to do the front. The Autozone compressor is the type that you have to put down through the spring, so it won't work for the front as the shock is obviously in the way.
Old Oct 9, 2007 | 10:56 PM
OldeSkool's Avatar
yeah thats what most people use
autozone has that kind to rent also... you have to get the right one from them
Old Oct 9, 2007 | 11:02 PM
SIK02SS's Avatar
but at 12.99 that might be worth buying...hmm
Old Oct 9, 2007 | 11:05 PM
OldeSkool's Avatar
agreed, especially if you do the job more than once in your life... 6 dollars on gas to rent it once is less than 12.99 --- 12 dollars on gas to rent it twice...
Old Oct 9, 2007 | 11:08 PM
SIK02SS's Avatar
AND you know how its been taken care of. i'm not gonna lie, last time i rented it, i was scurred!!
Old Oct 10, 2007 | 08:02 AM
UMI Performance's Avatar
Here is the one we got- http://www.harborfreight.com/cpi/cta...emnumber=43753
Those other ones work OK, but once they are used so many times they strip and are no good. At least the ones you by at Advance Auto are junk. So far the one above has worked good.
Old Oct 11, 2007 | 08:50 AM
sdiddy's Avatar
Well the spring comprssor worked, but was a PITA as most people told me to expect. Unlike the how to write up, I used an impact wrench to tighten it down because when using the wratchet, once the tension builds on the spring compressor it's nearly impossible to compress it any further without the spring/shock trying to turn over. I just did a little bit each side and it worked flawlessly.
Old Oct 11, 2007 | 09:35 AM
robertbartsch's Avatar
I used three of the cheapie HF units for my front springs.... seemed to work OK. make sure you oil the threads and go slow.....
Old Oct 12, 2007 | 01:06 PM
I don't think the cheapie HF units are made for comerical use so don't plan on using these more than a few times.
Obviously, messsing with springs can be hazardous to your health, so be careful!
Old Oct 21, 2007 | 07:05 PM
bearcatt's Avatar
Here's the manual.
http://www.harborfreight.com/manuals...3999/43753.PDF
Old Oct 21, 2007 | 08:08 PM
z28bryan's Avatar
The autozone one is free to rent. You just pay a 40 something dollar fee to hold it and they refund you fully when you return it, and you can return it whenever you want to
Old Oct 23, 2007 | 04:36 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
I have the exact compressor as mentioned by UMI Performance - works well and is made well.
Nice thing about that model is the fact that when you turn the screw, it compresses both sides evenly and at the same time. The individual style is a PITA cause you have to first tighten one side a bit, then do the other, then back to the first, etc.
Old Oct 23, 2007 | 12:31 PM
bearcatt's Avatar
Smile
I went ahead and ordered the spring compressor recommended by UMI yesterday also.
Old Oct 23, 2007 | 07:31 PM
WonQuickZ28's Avatar
Ive used both, go with UMIs suggestion, the strut spring compressor is so much easier and faster to work with.
Old Oct 23, 2007 | 08:32 PM
koolaid_kid's Avatar
I agree with the UMI selection. With as much potential energy that is contained in a compressed spring, don't risk injury with that cheapo junk. It is just not worth it.
Old Oct 24, 2007 | 05:44 PM
InsaneAuto86's Avatar
Just bought it tonight. I like how the instructions tell you to assemble it the opposite of how it looks on the box...
Old Nov 8, 2007 | 03:17 PM
bearcatt's Avatar
I just did my springs/shocks with that spring compressor,
a little cumbersome to use, but it worked well.
