Thinking about SFC's... any difference?
Old Jul 22, 2003 | 11:37 AM
  #61
trackbird's Avatar
Default Re: Thinking about SFC's... any difference?
You need to factor the amount of stiffness acheived versus the weight gained. I personally like the MAC subframes and other subs that just tie the front and back of the car together without the added weight of the X piece. I dont feel the supposed "added" stiffness is worth the extra weight...
Chris, that is an interesting thought. If I may, I'll share my views on the X-brace design.
As far as those "pesky cross braces" go, they will add more chassis stiffness per pound than a straight (2 point) connector.
We have to consider the properties of the material and the nature of the problem.
When a chassis flexes, its size and shape are altered (temporarily). When you drive over a speed bump with only one wheel (we'll use the drivers side front wheel for this example), the chassis stretches. When the driver side front wheel runs over a speed bump, it travels upwards and twists the chassis upwards as well. This increases the distance between the drivers side front sub-frame and the passengers side rear subframe. Simply, it stretches. This is the nature of the problem.
Now, consider kite string. It sure isn't stiff, and it bends easily...but it is strong in the one direction we need help. It's strength is in tension. A thin piece of steel has similar characteristics. It dosen't have to be terribly heavy to offer resistance to a stretching load (we have to worry about ultimate tensile strength and permanent elongation....a much more complicated discussion). So, a couple well placed (reasonably light weight) diagonal bars on a subframe connector will do wonders for eliminating chassis flex. Potentially, a connector design that utilizes a form of diagonal bracing can reduce the size of the "2 point" portion of the connector while giving up no (or nearly no) chassis stiffness. This potentially allows for a connector that is lighter in weight and stronger than a 2 point design.
As a side note. Consider a sway bar (for your suspension). A sway bar is a heavy chunk of steel that is designed to resist "twist". A 2 point subframe connector is asked to deal with this same type of twisting load. Now, we all know that sway bars flex and there is still body roll present (even with that large chunk of steel under the car). This is basically the same thing we have to contend with on a 2 point subframe design. We know it will twist. It is simply a sway bar with longer "arms". The longer the arm on a sway bar (diameter and length being equal), the "softer" the rate of that bar. So, we now have a 2 point sway bar (2 point connector) with the entire width of the chassis for "arms", to offer leverage to try and twist the bar. The cross brace becomes a light weight way to eliminate much of this flex with out resorting to 5 inch diameter tubing to get the necessary torsional rigidity.
Just my thoughts.....
Is everyone still awake?
Old Jul 25, 2003 | 11:20 AM
  #62
DGOETZ's Avatar
I'm awake.
Trackbird I know your moving but www.arp-bolts.com has information on the bolts they make.
I just read about it CHP September 03 haven't been there yet but it should be enlightening.
Will their bolts compare to others? maybe
Yes I completely agree about the car body being the weakest part of equation.
I make nuts that spread this area out instead of using standard nut and washer arrangement.
These nuts provide 54% more area than the standard nut/washer combination.
It's still a compromise
Old Jul 25, 2003 | 11:01 PM
  #63
trackbird's Avatar
As I remember (from the last time I looked at "ARP vs. Regular bolts"), the ARP will generate signifigantly more clamp load than a standard bolt of the same size at the same torque value. They use special (proprietary) alloys that have specific characteristics needed for each application. I'll see if I can find my ARP catalog and my book anytime soon.
Old Jul 28, 2003 | 08:25 AM
  #64
02RedWS6's Avatar
Why don't you guys just come up with a new bolt... If you are trying to reduce the slipping of the SFC vs. the mounting points then create a bolt with a ridge all the way around the bottom of the head. Not just a raised portion but an actual 'flange' if you will. This could then fit into a groove mirrored in the SFC. Granted this will not fix the weakness of the uni-body but it will hold everything in place a little better. To fix the uni-body... maybe a weldin backing plate. yeah yeah yeah... I know the purpose of bolt-ons is to actually keep you from having to weld anything to the car and ease of installation but if you are going to make a super stout setup then you will have to strengthen the uni-body, period. Otherwise, as I am reading over the past posts, any SFC will strengthen the uni-body construction. Also, refering back to past posts, the more mounting points the better. So a three point SFC will stiffen the car more than a two point. So the moral of the story is... "If you can afford to do something for your car the best thing to do is to install a good SFC." As for me weight is not an issue. I have no intention of racing my T/A... (except for a red light from time to time... but only to the posted speed limit of course... )
Old Jul 28, 2003 | 08:42 AM
  #65
mitchntx's Avatar
I have been reading this and I think an important point has been lost, forgotten or just overlooked.
While honing in on the bolt strength, the strength of what you are bolting too is highly questionable.
As I lay on my back, looking at the potential mounting points for ANY SFC, I don't see any structural part there that could withstand the sheer forces of a grade 5, much less a grade 8 bolt.
I also think that there isn't enough clamping force that can be applied to keep said forces from causing SOME movement.
There has to be enough room to get the bolt through the holes. Those tolerances alone will allow for movement.
Disclaimer for those who are **** retentive:
JMHO
Old Jul 29, 2003 | 11:00 AM
  #66
DGOETZ's Avatar
Like I've said before a timeless debate.
I think I'll stick with the Grade 8 bolts and large 2 hole nuts I currently supply with my coupe version subframe connectors.
Did I mention that these items are a compromise.
I hope the Gen 5 F-body has a full frame that would solve several problems.
Old Jul 29, 2003 | 11:56 AM
  #67
trackbird's Avatar
I think you'll find the weakness to be what it is attached to and the concentration of forces in that area, as well as the potential for "sliding" motion that reduces effectiveness.
Mitch, I glanced on that earlier....but I didn't make much of a point of it....
I think all connector designs are somewhat of a compromise....it simply needs a cage.....
Old Jul 29, 2003 | 12:23 PM
  #68
mitchntx's Avatar
I guess the point is that there is really no need for grade 8 bolts when attaching whatever to 12guage stamped metal. The meal will tear long before the bolts give way.
Now, which is an easier repair? a bolt replacement or ripped metal?
Old Jul 29, 2003 | 01:19 PM
  #69
trackbird's Avatar
While you are welding that "tear"....
Old Jul 30, 2003 | 07:41 PM
  #70
BlackoutSS's Avatar
Yes, as I have continued the search for the right suspension subframe connector for my 02 SS A4, I started out with the standard SLP black bolt on subframe connector. Then, I started to look and watch some of the 4th Gen. GM F-body that were involved in T-bone accident, side impacts, and other serious crashes. My family has been in the insurance business combined for over 80 years (all types). What I learned is that a bolt will not hold to the force of the impact. Anytime a weld is added to a body structure, this will surely strength up the compartment area. So, off with the SLP bolt on, and now to find the strongest Subframe connector on the market. Found it.
www.globalwest.net
Part #905
Made out of 2" roll cage .125 wall tubing. And welded in with big thick pockets too.
Excellent protection IMHO
Old Jul 30, 2003 | 10:43 PM
  #71
trackbird's Avatar
Weld your SLP's....
Old Jul 31, 2003 | 08:27 AM
  #72
02RedWS6's Avatar
Weld your SLP's....
I agree... The SLP's are a three point design and have the benifit of the extra support in the middle.
Old Aug 4, 2003 | 05:52 PM
  #73
sawedoff's Avatar
Titanium Subframe connectors can only be bolt in. And to what end. Any bolt in SFC is only as good as the bolts and bolt holes that hold them in , and that is not very good. The forces involved in this area will easily overcome the clamping forces of some bolts.
Titanium cannot be welded to the steel. The word "Titanium" sounds good, but if you read the signature of the guy offering these, he says this,"They call him the March hare, because he is crazier than one".
I think he got that part correct.
LG
Lou, these won't use conventional fastening systems, meaning, no threaded fasteners. They are held in place with a type of gravity locking system developed in the aerospace industry. There will be virtually no flex under load with this system.
Old Aug 4, 2003 | 06:12 PM
  #74
sawedoff's Avatar
Sawedoff,
I think you may be on the right track. But, I have a few questions (these are real questions, not "stirring up crap", meaning, don't misunderstand, I'm not attacking you or the idea, I'm just curious).
How will these attach? I'm not a structural engineer, but I was pretty sure that titanium needed to be welded in a dust controlled enviroment and could not be welded to steel (can it be brazed?, also not sure). I may be wrong on both counts, which is why I am asking. I did find a few links that talk about weld technique and quality (mostly referenced as a mil spec application).
http://www.eng-tips.com/gviewthread..../178/qid/61396
http://www.stainless-steel-world.net...um/welding.asp
http://www.timet.com/fab-p11.htm
http://www.demon.co.uk/cambsci/books/book55.htm
(the one above looks quite interesting).
Anyway, just a few things I found that got me thinking. It may be possible and work just fine (I do mig weld, but I'm not a "pro"), but I was getting the idea that welding titanium to steel is not exactly a "driveway and a 6 pack" job. But, I have found more questions than answers, so I thought I'd ask. I'm guessing that you have reasonable experience with titanium (if you can get it cheap, I'd say you must work with it....at least more than I do). Anyway, I though I'd toss these out...(like I said, I'm on a quest for info, and not trying to be a butthead....I just have in depth questions).
Thanks,
Kevin
Kevin, these won't weld in or be fastened in with typical threaded fasteners. The goal was to create design that could be removed in a minimum amount of time with few tools. They will be held in place, with a type of gravity lock. So they won't flex or give, when under stress. I have no problem getting titanium, and it's excellent quality stuff, with the certs that go with it
Old Aug 7, 2003 | 11:09 AM
  #75
DGOETZ's Avatar
Weld your SLP's....
I almost agree...
The coupe version I make have three point attachment and can be welded if you choose. Looks better as well.
Just my thoughts
Old Aug 10, 2003 | 01:30 AM
  #76
Cheatin' Chad's Avatar
With all this talk of chassis stiffening I am surprised no one has mentioned seam welding.
Old Aug 14, 2003 | 09:05 AM
  #77
DGOETZ's Avatar
Well it is an option but with everything compromises those damn compromises.
Old Aug 14, 2003 | 10:55 AM
  #78
Dr. Evil's Avatar
www.globalwest.net
Part #905
I've also heard excellent things about the Global West connectors. Thats what I'm going with when I have the $ to get 'em.
Old Jan 6, 2004 | 04:06 AM
  #79
ProjectRS's Avatar
Whats the deal with the titanium SFC's? Are they ready yet?
So are the SLP SFC's the "best" right now? (strongest)
Old Jan 8, 2004 | 07:31 PM
  #80
v8pwr's Avatar
Default WOW TITANIUM SFC's
I ALSO WOULD BE INTERESTED IN THEM AS THEY WOULD BE LIGHT AND STIFF.I WAS CONSIGERING THE GLOBAL WEST SFC's.PLEASE PM ME SAWEDOFF.
