Spring swap instructions
Old Oct 15, 2007 | 07:46 PM
FastB's Avatar
Default Spring swap instructions
I know I saw it on here somewhere and I tried searching for it. I am going to be swapping my eibach sportlines for my stock springs and I want to find the post on doing the spring swap so I have all my ducks in a row before I do it. If anyone can point me in the right direction. It was a great post with pictures and everything. Thanks
Old Oct 15, 2007 | 08:00 PM
2K2WS6TA's Avatar
front http://www.ls1howto.com/index.php?article=6
rear http://www.ls1howto.com/index.php?article=8
Old Oct 15, 2007 | 09:51 PM
HavATampa's Avatar
Sticky's can and should be your friend.
https://ls1tech.com/forums/suspension-brakes/422236-lowering-guide-newbies.html
Old Oct 15, 2007 | 10:54 PM
stevensLS1's Avatar
haha thats funny i just did this last weekend. make sure you go to autozone and by a spring compressor. it should be a long rod with two "clamps" on them. looks almost like a big c-clamp. if you need to know anything lmk.
Old Oct 15, 2007 | 11:27 PM
Braunbeck's Avatar
How long did it take? I'll be doing this, this weekend if I can get Saturday off and also be using a shop with lift, spring compressor and air tools. So I hope that helps out.
Old Oct 15, 2007 | 11:40 PM
stevensLS1's Avatar
backs 10 minutes? just unbolt the shocks and the rear will drop down. the front will take a little longer since there is more work involved. but im sure you'll be fine. just make sure you have that spring compressor!! good luck also.
Old Oct 16, 2007 | 01:34 PM
FastB's Avatar
Doh! I even looked there, just missed it down at the bottom. It is so small.
https://ls1tech.com/forums/showthread.php?t=422236
Old Oct 16, 2007 | 01:35 PM
FastB's Avatar
Yeah I borrowed some compressors, just gotta make myself do it now. I will be selling the eibachs as soon as I get them off.
