How do SFC’s really work?
Some just connect the front and the rear of the car without any contact in the middle. I can imagine they avoid stretching and twisting of the body, but not its flexing.
Others don’t connect front and rear but are welded on many spots under the body. They for sure avoid flexion and maybe a certain amount of twisting.
Others have a central connection to the X-brace with some transversal reinforcement. Due to their angled shape they (to my opinion) can’t really avoid a stretching. In the middle they don’t have a direct connection to the body, so I can’t see how they can avoid bending.
Due to their linkage they may avoid some body warping.
Does it really matter how SFC’s look like?
What do you guys think / know?
Thanks
Stefano
I put in my UMI Subframe Connectors and noticed no change really. I guess because I put it on at an early age instead of a high-mileage wagon on wheels. I also went with the two-point to save weight. I'm sure the 3-point is sturdier but I don't want it at the expense of added weight.
They are supports for the floorpan that just stiffen the chassis a bit.
By the way: your bars and shocks are working grate, now I need to stiffen up the body a little
http://www.lmperformance.com/4886/8.html
"Strengthen your front sub frame assembly and eliminate shock tower deflection by connecting the shock mounts together. Built with heavy duty 1/4" mounting plates and 1.25" x .095" tubing. This unit allows you to pre-load the brace for maximum rigidity! "
I was thinking it was possible to pre-load the chassis too
What condition I'm not satisfied with: the typical convertible F-Body twist and bend.
Aren't SFC's supposed to be installed with the car weight distributed even on the 4 weels?
Would this be a way to preload the SFC's? Let the car hang during the installation so that the SFC's will be under tension once the car is on the floor?
Install them and then shorten them a little.
If they are a little under tension wouldn't they stiffen ou the body a little more?
Sam, does that tunnel brace really make a difference?
Sam, going back to your explanation:
"If you took a ruler, and twisted and/or bent it, then stacked another rule on top of it, it'd be harder to twist of bend the two of them together. That's basically the deal with SFC's".
Does the distance between the "rulers" make a difference? In our case: does it matter how far the SFC's are from the floor pan?
I can imagine that a higer distance is better, but this means less floor clearance...
