G2 torque arm
!What about the torque arms? I want the absolute best one for daily driving. It has to be quiet, last the life of my car, fit with my borla and SLP SFCs, install very easy!
Under this criteria ...
It runs in the same space that the factory unit uses, so any aftermarket part that is engineered and designed to use with the factory TA will work.
Mine makes no noise what-so-ever.
The fact that it has a spherical bearing up front, means that it won't bind in any direction. It's design is simple which makes it strong.
Sometimes the cheapest price is not the best value ...
Here is the key to this question.
With the G2 Torque arm you will NOT have any more brake hop! so you will never have to worry about it any more, and you will be able to go deeper under braking. You will finally be able to use the brakes to their fullest, rather than "tiptoeing" up to the point of HOP.
Now that is worth the money ( and the 15% sale is still on at LG)
If you try it and have any brake hop, I will take it back and refund your money.
Thanks
Lou G
LG Motorsports 972-272-7753
2) How much work/time to put the front mount back to stock?
3) The common cure for brake hop was addressing the F/R brake bias. Can someone shine the light on how the G2 torque arm eliminates brake hop? I would look forward to installing a more agressive rear pad.
Thanks
Returning to stock is as easy as unbolting the G2 and bolting up the stock piece since there is no modification required. I found the G2 torque arm to be an easier install than the stock part.
IMHO its the best torque arm on the market (best I've seen anyway).
Seems like they've been out of production for a while. I found a supplier and ordered one last week. Apparently it was the last one they had in stock. It arrived without the bearing or mount. I'm in contact with the supplier, but it doesn't look good.
If they can't find or get the mount, I guess I have a few options. They either let me return it for a full refund, I keep it and try fab my out mount, or I have a large paper weight. I really like the idea of the bearing for the front mount unlike every other one out there that uses a bushing.
Does anyone have a close up picture of the bearing or mount? A number off the bearing would be awesome. I would hope the bearings are replicable for when they wear out, even if that means grinding off the old one and welding on the new one.
