Who makes an abs delete or who sells them
http://mysite.verizon.net/vze8nspr/l...rts/index.html
Ask for Brian or Sam, and they are a sponsor on here.
Thanks for the comments and links guys.
For reference, our ABS delete kits completely remove the entire ABS block and ABS bracket. This removes as much mass and opens space in the engine bay for increased air flow and room for supercharge/turbo setups. Most importantly, ALL our kits include a proportioning valve which enables you to adjust brake bias. Kits start at 139.99 online.
Brake bias 99.99% of the time will NOT be biased correctly without the control of a proportioning valve. When ABS is removed, you have no feedback of adjustment through a computer(ABS used to aid in control of your braking). Through the use of the ADJUSTABLE proportioning valve, you can increase brake performance, shorten stopping distances quicker and safer. The rear-end tends to lock first due to it being lighter, if the brakes are not biased and the rear locks up before the fronts...on a turn for example, you will have a tendancy to spin out quickly.
Let me know if you have further questions. All kits are in stock and ship typically w/in 24 business hours.
Moderator
Couple questions:
Does anyone know if performing this ABS deletion sets any codes that would cause the car to fail emissions inspection?
Because I have such a large difference in tire size between the front and rear, when I run my ET Streets, does performiong this deletion avoid the ABS error and subsequent odd handling that occurs when the alarm appears?
Thanks!
Thanks!
Emissions does not effect your ABS controller nor should it affect passing. Some states may vary, maybe a mechanic could clarify this for you.
Your braking performance will be enhanced...using our kit, you'll be able to bias your brakes as well.
