Brake Convertion
We'll since it's winter and I have a good paying job I am stock piling parts, I have a lot to catch up on since I was in school. My question is what do I need to convert my car over to a better brake system, I am going to get a bigger wheel/tire setup to suit the larger brakes... I have been looking at a C5 vette setup which I can get for pretty cheap, I just need to buy the pieces seperatly...
For the front I figure I need:
- Caliper mounting bracket
- C5 Calipers
- Brake roters
- ? Do I need a C5 brake line as well? I am looking to upgrade to stainless lines anyways but not sure if the C5 or Camaro are any different...
For the Rear:
- C5 rear caliper
- Brake roters
- Mounting bracket
- ? Same question about the brake lines?
I know some of you guys have done this before so I am sure you can help me out with this. If you guys have other suggestions on where to look/what to do I am all ears, I'm just trying to keep it within reason ($).
Let me know what you guys think.
Thanks
Devin
As far as converting the rear brakes, there really is no advantage to doing that. But do a search and read up. I'll try to find the link.
https://ls1tech.com/forums/showthrea...+rear+corvette
This is not just a bolt on.
But you can't put Corvette rotors on your F-body without relocation brakets. The rotors are larger and the calipers need to be moved to align up. So you need the relocation brackets and have to modify the spindles.
