spohn Tubular Adjustable Torque Arm
just put my spohn Tubular Adjustable Torque Arm on it is a tunnel brace mout the car is real stiff in the back end just wonted to make sure if that is right or not
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
thats the only thing i swoped out and now the suspension seems alot stiffer than it was befor just by pushing down on the back of the car just wonted to make sure that was right or not
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
The Spohn unit doesn't have the front end play like the stock unit. The stock unit has a slip front mount and the Spohn has a solid front mount transfuring foreword movement to upward movement.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
I have the Spohn tunnel mount on mine, love it.. I'm guessing you have some type of vibration now, by your last post? Check to make sure you seated the U-Joint correct to the diff, would cause a bad vibration if it's not on correctly
I really noticed that on mine too..
any one else ever have any bad vibrations with this TA? put one in when i did my 9", was told to leave the front mounts little loose(just snug) but have a very bad vibration. i know it is not the DS, as i have tried 2 different units and still the same. need help, vibration is driving me insane.
