Floor mount vs stock length vs cross bar mount
Tunnel mounted torque arm vs stock length vs cross bar mount
I am about ready to buy a new Torque arm for the upcoming season and i am not sure which to buy. Has anybody had any problems with the tunnel mounted torque arms with the associated crossmember? Is there a reason i should not go with this setup? The shorter arm claims to help 60ft times. Should i go with the cross brace model that mounts to frame connectors? Do i have to have boxed vs tubular connectors to use these? I do not want to add much weight also and will probobly go with cmoly. Thanks
Hello,
If you need any help please contact us and we will be glad to assist.
For drag racing I would recommend the shorter style tunnel mounted torque arm. We have very good luck with these and have vehicles running in the single digits on them. We offer quite a few options depending on your exhaust set-up and they can be supplied with a built n drive shaft loop as well as Chrome Moly is a option.
If you have any questions please ask. Thank you!
Ryan
Ryan
Thanks for the reply. I will take a look at your products. I have a tunnel brace and loop now that i will have to remove. I just did not know how strong the mounting point would be. Have you had any problems bending/ripping that point?
To be honest, we have not had any issues with the mounting plates. Although on a high powered car I could see it being a issue in the future.
Our solution to this our 3-Point SFC's, they bolt to the body of the car first and then the torque arm bolts into the SFC's. This allows all the stress from the torque arm to be applied into the SFC's instead of the floor of the car. Please reference the picture below and let me know if you have any additional questions.
UMI - that looks like the underneath of my trans am besides different diamond connectors. I've had good luck with my umi tunnel mount torque arm. I'm working on my second car and second year with this same torque arm street/ track car and I couldn't be happier with it. I opted for the mounting bracket that has clearance for the header y pipe and it has held up great.
Also the built in driveshaft loop fits really nice.
Thanks again i was just looking at that setup. Do you have a weight on the CM version of those frame connectors. I have LT pacesetters and 3 inch y pipe setup. I have around 415wrhp so far. Do you have any package deals for that setup in Chrome Moly?
The weight savings for the SFC's in Chrome Moly is 4lbs, the torque arm is 2lbs so it is nothing real significant. The torque arm is built from Chrome Moly for the strength rather then the weight. We recommend the Chrome Moly version for vehicles running 10's and faster in the 1/4 mile.
Let me know what you would like and send me a PM, I will see what I can do. Thank you!
Ryan
Ryan
LS1Tech Premium Sponsor
