Pro Kit vs. Sportlines
yea i may be getting some new wheels to put on it soon also, my zr1s are for sale and want something different, found some centerline wheels that look like the pro stars but a little bit different.
Ive had sportlines for almost 3yrs now. I like them. If you learn to take angles when driving your car and take speed bumps slow you will be fine. I only have a catback exhaust and it will occasionally scrape places. The ride isnt too rough either i dont think.
Look guys, the sportlines look great on the car, but on paper and on the road, they are an engineering mismatch of too low a spring rate and not enough ride height or allowed suspension travel. Id go with a different spring. BMR, Strano, MAC, and many other companies make springs that work...sportlines just don't.
www.stranoparts.com
www.umiperformance.com
edit: and whoever said that sportlines are stiffer than the prokit is wrong. The sportlines are softer
Eibach V8 Prokit 400 80-137
Eibach Sportline 360 80-137
#33
This website will help you out:
http://www.angelfire.com/my/fastcar/suspension.html
Basically, pro-kit is low. Sportline is way too low and soft.
#34
no problem. glad i could help
Thats the site i get most of my spring rate data from. Very good list.
#35
Prokit is very nice and middle of the road. I have them with 4/3 konis and i don't scrape much of anything. If you do the lowering and you race the car or want it to handle/launch better yet you should also look into adj. panhard rod lower control arms with the relocation brackets. Otherwise wheelhop is even more pronounced.
Heres my car on the prokit:
![](http://i50.photobucket.com/albums/f344/ws6jim/100_1059.jpg)
