which one, poly/poly or rubber/poly
Good luck!
Good luck!
Then you could get poly for the body attachment end for the perfect combination for this part. It should be quiet as well.
Good luck!
What's your reasoning behind that statement?
Let me voice mine ...
Remember, the center bolt in the bushing is nothing more than a location and pivot point. The inner sleeve and bushing all move as the LCA goes up and down.
A non-metallic bushing binds because the LCA twists in the mount when the body rolls like through a corner, jamming the bushing compound into the side of the mount, creating friction and thus increasing effective rear spring rate. And we all know that a increased rear rate will cause the car to push, especially on corner exit, under power.
A poly pushing is harder and less pliable. Therefore would slide easier on a metal surface of teh mount, under a given load, than would the softer rubber compound. The softer rubber would be "stickier" because it's softer.
I equate it to softer and harder compound in tires. The harder the compound, the less traction it will have, while a softer compound will grab a lot better.
What are your thoughts?
). It will reduce binding or bind less than poly. This is one of the reasons that many racers say to stay away from the 1LE rear bushings, they help locate the axle at a cost of increased suspension bind. Ground control (www.ground-control.com) says this about poly bushings (in their F-body catalog, online):These popular kits are promoted heavily in all the magazines, but have some significant disadvantages , even when compared to the stock 1LE bushings . We sell these bushings in pairs (for one end of each of your control arms) and recommend them for use with our spherical bearings described below
Anyway, these are my thoughts on the matter, sorry for the novel. Did I make any sense at all? (It is 1:42 am and I just installed an adjustable clutch quadrant and clutch cable in a friends Mustang GT....so, I may be a little tired right now...if so, I'll correct the errors tomorrow).
Kevin
Sure rubber is more pliable. But where in heaven's name can the rubber move? The entire bushing is clamped between two pieces of metal, one on either side ... the mount.
So, if a twisting force is applied to the LCA, either the mount has to give, the bolt has to fail, the arm itself has to twist or it remains rigid.
I contend it remains rigid ... but the forces that are trying to twist it are still there. That will add even MORE effective "torque" to the mount against the bushing ... i.e. more clamping force ... i.e. bind. And the bushing can't deflect because it's clamped in all that metal.
So what happens when the suspension attempts work as the car goes over a small bump in the pavement? Or the body just tries to roll normally when transfering weight in a turn? It can't because it's all bound up. It can't move with the normal spring rate ... this increased rate equates to bind in EITHER bushing type ...
The world as I see it ... open my eyes, please!
M
All that aside, I am not a fan of rubber or poly. My thoughts on the rubber may require you to look at it from a different perspective. You are looking at the properties rubber and poly strictly as they relate to side loading and bind (that increases spring rate). If we eliminate the spring rate part for a minute, consider simply the twisting action that a control arm (and bushing) sees during body roll or when one wheel hits a speed bump, etc. There has to be some give to allow the axle to move in a way that allows the bolts to be "non-parallel" to each other. I simply contend that rubber more easily allows this rotation than poly. Poly will increase your rear roll rate considerably, it simply dosen't want to allow any rotational motion. The rubber will give. That was my main point for picking it as "the lesser of two evils" (though, admittedly, it is not that much less evil). I would suspect the binding with regard to spring rate to be very similar between the two bushing types. Poly has very little "give" which will place substantial "side loading" (bind) against the metal surfaces that it rides against. However, poly is more slippery (back to your thoughts on tire compounds...it has less grip). Rubber will give somewhat (and even more with the new bushing that GM is using, compared to what was on my 3rd gen), but has more "grip". I'd like to measure the difference in energy required to move a LCA vertically while it is twisted with say...15 degrees of "twist". And then do this for both bushing types. I am starting to wonder what the results would show.
So, basically, we agree....(we just view the finer points differently, I think the result is the same). Rubber and poly are poor choices for LCA bushings. I would take my chances with the rubber over poly since I think the rubber will have less effect on "roll stiffness" (it won't try as hard to keep the rear parallel to the chassis). If we think of the lower control arms on the Fox bodied mustangs that the drag guys used (solid bushings or poly/poly), they were cracking the mounting points on the chassis due to twisting loads. I don't think there is any danger of a rubber bushing doing this damage and that, simply put, may be the beauty of a rubber bushing (it simply sucks "less bad").
These are just my thoughts, let me know what you think.
And thanks for the tech on the new bushing design in the LCAs. I wasn't aware of that.
Bushing use is somewhat of pet-peeve of mine. I spent hundreds of dollars on poly/poly LCAs, searching for an LCA that woukld actually work.
The problem was, I didn't fully understand (assuming I do now
) the physics that was going on back there.When I see someone about to plunk down $150 for poly or rubber bushing LCAs, I have to chime in and explain that for another $50, an LCA can be had that actually does what ALL it's intended to do.
Ryabut98, that's why the message boards are here. Besides, Mitch and I seem to have the most interesting conversations. If I ever find myself in Texas, I may have to look Mitch up.
If a spherical bearing is placed at one end ( the diferential side ) and poly at the body attachment end would this be enough to eliminate bind.
I building some prototypes with these very features
I believe this binding to be detremental to the longevity of the LCA mounts.
Just my thoughts...
Kevin
We then decided that if you must have a quiet (stock type) ride and refuse to use a Heim joint, you are left with rubber/rubber or poly/rubber for your bushings (one type on each end or both poly). This dosen't seem to be much of a choice, but out of the two, I'd take my chances with a rubber/poly in an effort to minimize the effect that either type of design has on handling. Basically, both are a compromise, we just decided (or I think we did) that rubber is "less bad". The fact that rubber is soft helps the suspension move with less resistance, it also allows the suspension to move in ways you don't want it to. But, that is pretty much the definition of compromise, it does everything and none of it well.
Does that clarify it somewhat?
If not, just ask...
