2-3 shift clunk
do most people with chassis mounted ta's have some clunks going on? Im gonna have to check out the pinion angle when i get back from europe.
Many guys say that poly motor and rubber tranny is the way to go. I went all stock as I want comfort. YMMV
Visual inspection is not useful. Push up on the tranny tail housing to see if it comes off the X-member. To test the drive shaft u-joints put the car in gear and twist the shaft with your hands. If it has rotational movement, you have junkie joints!
If you need to get one or both wheels off the ground for this, then use the E-brake to lock the back wheels.
The shift clunk did not go away though. It got alot alot better. It was pretty bad, now its bearable.
I was able to very slightly move the driveshaft back and forth, but the part going into the tranny was moving as well.
I still have to check the Torque arm angle.
I had the ES mount. I did 2 things that fixed that. With the BMR relocation kit, I had a bit more freedom to position the crossmember and thus alter the transmission location and driveline angle. First I switched to the Prothane mount, I noticed it had a slight height difference of 1/16 of an inch, just enough to change the angle of the transmission. Then I yanked on the transmission while reassembling to the driver's side.
The change was noticeable immediately. First my idle rattle was gone, just my normal cam lope. Second, at 60mph the harmonic was gone. Third was at high speed, the car felt rock solid and more confident. I was able to then change the instant center up a notch too.
It's really tough to measure the difference between stock and aftermarket parts, but I think that with the stock crossmember with the ES mount with the bumps shaved off kept my driveline in the same position. When I switched to the BMR relocation, the angle changed along with the height thus making any instant center change unnatural, let alone stock centering.
Its still more noisy than stock but not bad at all. And It also makes the car much smoother over the little stutter bumps/cracks in the road.
If the PA is off is sounds like the rear is slamming the ground even on little road cracks and the rear end and tunnel mount made lots of clunking noises. Almost scary to drive the car that way.
Now its all good and I couldnt be happier.
All it takes is adjusting and test drives.
