my BRAND new Koni BROKE during istall... WTF?! pics included
#43
good stuff man... I got the same koni's more than a month ago and the ride is awesome and well worth it. Glad to see no hassle from Koni with your previous problem. Gotta make sure I have my receipt jus-in-case anything happens later down the road to mine. All I need now is an adj. PHB
#45
QA1's are drag shocks, Konis are handling shocks, apples to oranges.
But FWIW:
https://ls1tech.com/forums/showpost....5&postcount=26
#47
install took me two serperate days, mainly because of the UMI torque arm and some problems with the exhaust not wanting to go back in place. But the rear shocks/sway bar were a breeze, as well as the front sway bar. The only thing that took a little time was the front struts, just cause you have to use the spring compressor, and it can be a PITA trying to get the spring mount to line up right.. its not that bad though! I am not sure how you do the rear springs, but im sure we can look up on ls1howto.com
#51
My shock just broke in the same spot today. I had a tire company install the springs for me. What a mistake. They had to take them apart once to install the washer. Then I had them take the darn things apart again to install the bottom rubber piece. One more time to install the top rubber piece that goes into the mount. I don't know how they did it, but they broke the darn thing in the exact same spot. I don't know if my warranty will work because I only bought one shock from summit racing, and already had the other side.
#54
Are you guys compressing the spring all the way down so that the upper mount will seat against the washer on top of the koni or are you compressing the spring half way so that the upper mount is not touching the washer and then trying to run it the rest of the way down with the nut. I just don't understand why this is happening as that bolt was the easiest thing to tighten during the whole install.
