Coil Over Help?
1. QA1 or AFCO coil over conversion. This will replace the factort shock and spring with a coil over type shock. You can adjust up and down.
2. Adjustable spring mount. This welds into the existing upper spring perch and replaces the rear spring. Also adjustable.
And the fronts are coil-overs (as are the stock ones) because the coil spring is over the damper. That's what makes a coil-over a coil-over. Adjustable height coil-overs are the ones that are threaded for at will height changes.
