ZO6 Brakes on 1992 Z28
You'd be better off with an aftermarket kit for your '92.
The Z06 uses a rotor hat that installs over a hub. The '92 uses a rotor with a built in hub.
Not saying it can't be done but you may need be the first to do it.
I'd start by looking at a '98 and up f body spindle swap and a C5 adapter kit.
Now, I know some guys put LS1 brakes on 3rd gens by cutting the rotor off of the rotor/hub, and turn it into a hub. Then you can slide the rotor over your newly made hub. No tech on how to mount the caliper though.
http://www.thirdgen.org/techboard/br...=zo6+c5+brakes
this is what I am doing. I am doing the Front and the back. There is a adpater kit that makes them work with the stock axel housings.
David, hit me with a PM either here or on third gen, I've been doing kits for years now and did a few of the kits in that link above. Glad to help you out. Please be advised that I'm running a 3-4 week backlog but will get you taken care of if you're ready to roll on brakes. Search my ID on TGO and you'll see what I can do, or Google me..that works too.
Ed
Ed
Ed
Ed
