what to adjust koni 4/3 to for cruising???
Old 03-13-2008, 03:23 PM
IA2000SS's Avatar
Default what to adjust koni 4/3 to for cruising???
I just got my Koni 4/3 today. I was wondering what to set the fronts and rears for just cruising?? I dont do alot of drag racing. I figured out how to adjust the fronts but im still kind of confused on th rears. Thanks for all the help I can get.
Old 03-13-2008, 03:44 PM
Bow94z's Avatar
Stock springs?
For the most part you tend to see ppl adjust the fronts to about half. turn the adjustment window all the way to full hard, then pull it back about 4 sweeps from full hard.
Rears, leave them on full soft...
These adjustments can vary slightly from spring choice
Old 03-13-2008, 03:50 PM
IA2000SS's Avatar
I have the strano springs
Old 03-13-2008, 04:02 PM
sidewayz28's Avatar
Are the rear shocks on the Koni 4/3 even adjustable?
Old 03-13-2008, 04:07 PM
Bow94z's Avatar
Well in that case do what I said above, I only cruise my car and have my fronts set 4 sweeps from full hard, and the rears at full soft..Love the way it rides
Yea internally adjusted, meaning they have to be pulled off the car, pull the "dust cover" down and there is a button you push down and the spin the rod, there will be 3 clicks to choose from
Old 03-13-2008, 04:12 PM
IA2000SS's Avatar
yea they are but there internally adjustable so i want to adjust them before i put them on otherwise i would have to take them back off
Old 03-13-2008, 04:16 PM
sidewayz28's Avatar
does anyone have a picture of the rears with the dust cover down? i cant remember what it looked like, and i dont believe i touched the rears. My car rides very stiff, but handles like its on rails
Old 03-13-2008, 04:28 PM
JD_AMG's Avatar
Looks like this except the body is yellow instead of red:
What are your fronts set at? What is your tire pressure at?
Old 03-13-2008, 04:46 PM
sidewayz28's Avatar
i went all the way to full soft, then i think 7 sweeps towards firm. front tires are 30#s and rears are 28#s
Old 03-13-2008, 05:08 PM
IA2000SS's Avatar
Alright i figured out the rears. so what u guys think for just crusing??? fronts 4 sweeps from full hard and rears on full soft or any other suggestions
Old 03-13-2008, 05:09 PM
JD_AMG's Avatar
I don't remember but I *think* the fronts have 9 total sweeps. Go all the way to full hard, then back down 4 sweeps. You should like that setting, it seems thats the norm, I have it on my car and love it.
This is what mine are set at. You can search "koni settings", Im pretty sure most are running this.
Quick Reply: what to adjust koni 4/3 to for cruising???
