Whats the name of that grease for poly bushings?
I cant remember the name of that grease that works really well on poly bushings, can someone help me out? When i installed my new sway bars they came with a small tube of lube but it wasnt nearly enough and now the bushings are creaking really bad when i go over bumps. I tried spraying some WD40 on them since i had it on hand, but it didnt do ****. Still creaking.
Help!
Help!
I've heard WHite Lithium grease works, I've also heard any PTFE based grease, synthetics, basically any non petroleum based grease should work.
THis site talks about a sticky green poly lube, I've never heard of that before:
http://www.polybushings.com/pages/bushinglube.html
On the very top of this link is lube:
http://energysuspension.com/pages/univ2.html
You can find it at Autozone, maybe our sponsors sell this or somethig similar?
LS1Tech Premium Sponsor
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Like what has been stated previously you need to use a full synthetic grease or we sell the Energy Suspension "Super Grease" in grease gun size cartridges. The Energy stuff is the best but a full synthetic will work fine.
Update: I got a jar of Mobil 1 synthetic grease at autozone for $6 and it worked perfectly. I globed it on like mad and now no squeaks! I think the true culprits were the perches where the sway bar mounts to the body. I lubed those up too and im good to go.
