Are torque arms weak points???
Old Apr 13, 2008 | 10:23 AM
jshelton2006's Avatar
Default Are torque arms weak points???
I recently finished my H/C/I package and 2 days later broke the torque arm off the rear end. Is this common or just bad luck? It broke where the bolts run through the back and the rear end...thanks
Old Apr 13, 2008 | 10:32 AM
Black02SLPSS's Avatar
Were you running an aftermarket torque arm or the stocker?
Old Apr 13, 2008 | 11:43 AM
the stock one with a prothane bushing...
Old Apr 13, 2008 | 12:03 PM
Ya that was the weak point. Not sure if it is a common occurance or not. But now would be a great time to upgrade to an aftermarket piece so you wont hafta worry about it anymore. Also, what numbers did you put down with your setup?
Old Apr 13, 2008 | 12:12 PM
davered00ss's Avatar
Moderator
Normally they break after you have removed them and not tighten the bolts enough. The bolts get loose & then the Tq arm breaks.
Old Apr 13, 2008 | 12:23 PM
stoverz28's Avatar
exactly what happened to me, but ive got a 12 bolt, 4 mounting bolts not 2 straight thru. Check them regularly!
Old Apr 13, 2008 | 04:47 PM
Moderator
Normally guys tack the bolts once they are tight.
Old Apr 13, 2008 | 04:52 PM
yeah i ordered a new Spohn one. I haven't dyno'd my car since i got it done yet. i just got a mail order tune to break everything in then i'll have it dyno tuned shortly. I'm hoping to hit 480+ at the wheels. Runs damn good!!!
