how low is too low for exhaust??
Old 04-25-2008, 11:59 PM
slowjoe99's Avatar
Question how low is too low for exhaust??
I have a stock height 99 camaro ss. I have PaceSetter LT headers and PaceSetter off road Y pipe. I wanna lower my car as low as I can, which i know is only about 1 to 1.5 inches with my exhaust. is there a way to tuck my exhaust up to keep it from hitting the ground?
Old 04-26-2008, 12:14 AM
383lt1impala's Avatar
i would like to know this info also...
Old 04-26-2008, 12:18 AM
FiredUpZ28's Avatar
I dunno about the LS1 but the LT1 Pacesetter Y pipe clearance is almost zero so I'm gonna go out on a limb and say no.... I mean you could always somehow raise your motor mounts, but that would negate the effect of lowering as far as center of gravity is concerned.
Old 04-26-2008, 12:21 AM
94'BLKBRD's Avatar
I had my 00' SS lowered on sportlines and I was running XS headers w/TSP td's, only had problems with the big speed bumps and some big dips.
Old 04-26-2008, 01:23 AM
SIK02SS's Avatar
just do a search for TDs and look at there heights...those are lower then ypipe setups
Old 04-26-2008, 11:58 AM
mcflyz28's Avatar
Lowest part of my car is the crossbrace for the BMR trak pak
Old 04-28-2008, 09:55 AM
95GreenZ28's Avatar
Yea my TA is my lowest spot. I have longtubes etc and I am dropped 2"
Old 04-28-2008, 10:07 AM
tylerdj's Avatar
You're not really going to get your exhaust up anymore than it is. I have LT's and will be going with a 1-1.25" drop.
Old 04-28-2008, 10:12 AM
95GreenZ28's Avatar
How much are you wanting it dropped?
Old 04-28-2008, 04:43 PM
slowjoe99's Avatar
I know I can drop it an inch but I would like to drop it 1.5 inches and be able to drive around without hitting every speedbump and scrapping when I pull into parkinglots
Old 05-05-2008, 05:22 AM
slowjoe99's Avatar
well i got qa1's so i guess i can set it where ever works best. it'll probably be around an inch...
Old 05-05-2008, 10:51 AM
z28bryan's Avatar
The lower you go, the higher chance you have of bottoming out. It depends on your header brand mostly and what kind of springs you use.
Old 05-05-2008, 10:59 AM
chupr0kabra's Avatar
I have Pacesetters and the TSP catted y-pipe. I avoid speed bumps like the plague, and I often find myself going out of the way and/or avoiding some places altogether, because I know I won't have clearance. You'll have to change your driving style.
I would look into finding an exhaust shop that can custom-fabricate a good y-pipe. Some shops do wonders with oval tubing, and if you find one that can modify the body brace points under the floorboards, they can tuck very tight. Just make sure they find a way to keep it from banging underneath.
-Mike
Old 05-05-2008, 11:40 AM
Turnin20s's Avatar
I have a Spohn tunnel mounted TA and thats the lowest part of my car. I have hooker LTs and I fabbed up my 2.5" x-piped exhaust and have it tucked up as tight as you can get IMO and I can't fit a pepsi can under my headers at stock height and I'm going to lower it with Strano springs. I won't be able to take my car and park in the upper parking lot at work because of the speed bumps, but thats really the only place that I won't be able to go around here.
I'd say just be careful and you won't have any problems
Old 05-06-2008, 06:00 PM
'02 WS6's Avatar
I'm on Strano's w/ Pacesetter LT's and TSP TD's and I only have about 2-2 1/2 inches of clearance. I have to take any dips/bumps at a strong angle going very slllloooowwww!!!
Old 05-07-2008, 12:29 PM
tylerdj's Avatar
How much of a drop are the Strano's?
Old 05-08-2008, 02:45 PM
camracingah's Avatar
The Z is lowered but I wouldn't say 'slammed' but every now and again we will scrape in certain areas. We try our best to keep the ride 'light'. Like big bodies are a NO NO. haha
Old 05-08-2008, 02:49 PM
Brickyard's Avatar
I have 2" from header to concrete, and an inch and a quarter front tire to fender.
