Rear Sway bar
Well im getting ready to put my 9inch back up in the car this weekend and found a BMR used 21MM rear Sway bar for a decent price. My question is, do they help out alot?
LS1TECH Sponsor
I agree, If it's a decent price, grab it. I use a similar stiffness rear bar as BMR, we just opt to do hollow vs. solid.
I would recommend a larger than 32mm front to go with it. I feel the best handling combination is 35/21-22 rear, or 32/19 like came on SS's and WS6's. I don't really like bumping the rear stiffness by some 33% or so and not doing anything on the front, which is the heavy end of the car. JMHO.
I would definitely not recommend a larger rear if you have a stock 30mm Z28 front bar, that's even more the wrong way, again in my opinion.
__________________
LS1TECH Sponsor
And because it is an SS you already have a 32mm bar... and a hollow one (lighter), and if you stay with that front, you should IMO stay with the stock 19mm rear. And that advice also costs me a potential sale of one of my hollow 22mm rears, but it's the right thing to tell you as far as I'm concerned.
32/21 is not an ideal handling combination, and only one year 1LE had that, but it also had stiffer front springs only and the bigger rear bar was to cover the softer rear springs. When the later '94 and up cars changed both front and rear springs, the bars reverted back to 32/19, which is what you have, and a front to rear ratio I feel is correct. My bars @ 35/22 are a very similar ratio front vs. rear.
__________________
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
If you have a larger rear bar than stock and a stock front bar, the car will be much more prone to oversteer, not understeer.
If you upgrade one bar at a time, get the front first.
