Summit Lowering Springs
After searching it seems that these are probably eibach springs (I had already guessed that because summit seems to use alot of edelbrock designs and I believe eibach is through edelbrock)
to the point, is anyone running these springs? No rumors or 'get what you pay for' but is anyone actually have these springs in there car and how do they handle/look?
Don't know for sure about the Summit springs, but I work for a Mustang retail company and we carry Eibach. We also have "our own" brand which is a set of Eibach springs that we sell under our name for a cheaper price (same exact specs). My guess is the Summit ones are actually Eibach ones as well. There is such a huge mark-up on their springs they can afford to have major companies sell them under their own name for a cheaper price.
You can always ask the rep at Summit who they buy from or who the manufacturer is.
I remember reading about them from someone on Camaro Z28, apparently they gave out shortly after installing them. I think you might be hard pressed to find anyone who is actually running them around here though because recently it's blasphemy to run / try anything but one certain brand of spring.
^ Pretty good... By their specs, they are identical to the LS1 Eibach prokits and LT1 Prokits, depending on part number you choose. Here are some of the other springs and their rates/drops.
Manufacturer Model Front (lbs/in) Rear (lbs/in) Ride Height Drop (in.)
OEM GM V6 93-97 223 95.4 0.00"
OEM GM V8 93-97 310 110 0.00"
OEM GM V6 98-02 257 114 0.00"
OEM GM V8 98-02 292 114 0.00"
1LE GM 1LE 360 130-180 0.00"
Eibach V6 Prokit 93-97 337 75-135 1.00"
Eibach V8 Prokit 93-97 377-600 94-160 1.30"
Eibach V6 Prokit 98-02 351 80-137 1.40"
Eibach V8 Prokit 98-02 400 80-137 1.25"
Eibach Sportline 360 80-137 1.6" / 1.4"
Hotchkis Fbody Springs 285-525 100-140 1.00"
G2 Super Springs 548 180-230 1.50"
Hyperco Hypercoils Fbody Springs 360-580 168-216 1.25"
MAC Fbody Springs 450-515 215-245 1.50"
SLP Level 1 Progressive 223-448 97-136 0.75"
SLP Level 2 Progressive 300-450 115-185 0.50"
BMR Fbody Springs 310-550 145-170 1.00"
Suspension Techniques Fbody Springs 428 161 1.30" / 1.70"
Edelbrock Fbody Springs 585 120-150 1.25"
DMS Springs LS1 98-02 325-630 95-160 1.30"
Its the same exact reason no one recommends buying an ebay electric supercharger over a real supercharger.
