Brakes failed while driving
Old May 28, 2008 | 04:40 PM
Alpha-Q's Avatar
Default Brakes failed while driving
while driving home from work my brakes was working fine for about a mile. Then when i came in front of a stop sign, i stepped on the brakes. I didnt slam on it. while stepping on it, it stopped half way and then the brake pedal went straight down to the floor. I had no brakes for like 4-5 seconds. Is it safe to drive the car?
Old May 28, 2008 | 05:33 PM
tbird31's Avatar
lemme think...if you can't stop a 3500lb car safely, i'm gonna say you probably shouldn't take it out of the driveway until you figure out the problem. common sense...
Old May 28, 2008 | 05:44 PM
phantomzer0's Avatar
Yeah no ****. Check your brake fluid and make sure everything looks okay. There is clearly a serious problem.
Old May 28, 2008 | 06:42 PM
ae13291's Avatar
check ur brake fluid
Old May 28, 2008 | 08:04 PM
AronZ28's Avatar
maybe a ruptured hose or rusted out line???
Old May 29, 2008 | 11:32 AM
twitchtwice's Avatar
that happened in my sisters honda. we had to change out the brakes master cylinder. so maybe you should take it to a local mechanic (trailer it there) and let them look at teh brakes.
Old May 29, 2008 | 07:34 PM
somws6bird's Avatar
Maybe the clamp on the brake arm fell out, happened to me once scared the crap out of me, very hard to see the clamp, you have to get a flashlight and look on the arm of the peddle. If your missing the clamp you can buy it from a gm dealer for I think 50 cents!
Old May 29, 2008 | 11:11 PM
Alpha-Q's Avatar
Talked to my mechanic and he said to bring it down and he's gonna put it on a hoist. I have a feeling it's my master cylinder. I hope i'm right.
Old May 29, 2008 | 11:35 PM
^^^^ i already said that
Old May 30, 2008 | 02:24 AM
Alpha-Q's Avatar
Thats where i got it from
