Front Upper Ball Joint Replacement, help!
http://www.autozone.com/R,APP377295/...ductDetail.htm
Or a pair for $38 shipped
http://cgi.ebay.com/ebaymotors/93-20...spagenameZWD1V
What he said......
Keep in mind, you're replacing the original BJ with a new one, so it absolutely doesn't matter how badly you butcher the retaining nut, rivets, etc... As long as you don't do any damage to the control arm, you're OK!
A good sharp chisel and a 3 pound, short sledge hammer should make short work of the heads on the rivets. Just a tip...On the other side, loosen the nut that retains the BJ to the spindle, but don't remove it completely. this will give you some support when you attack the rivets.
