Koni Adjustment window
Old Jun 27, 2008 | 07:12 AM
kirby's hawk's Avatar
Default Koni Adjustment window
I have Koni double adjustable shocks on my car. With the front ones, the adjustment window is facing the front on the passanger side. Would I be able to turn the shock to face the side while it on the car, or would I have to take it off and remount it?
Old Jun 27, 2008 | 08:23 AM
99ssleeper's Avatar
i dont think youll be able to turn it because the lower mount would not line up. mine on the pass side faces forward as well, i adjusted it with a small allen wrench...took a little time but it worked fine.
Old Jun 27, 2008 | 11:40 AM
Mean Green z28's Avatar
When you bolt it up to the top mount during installation, that's when you have to set it up to face outwards. I made sure the window faced outwards and even my spring was rotated correctly so I could access the adjustment easily.
Old Jun 27, 2008 | 12:00 PM
I wish I was the one who put them on. The owner before put them on, and I think I can get to them, but it will be a pain the ***.
Old Jun 28, 2008 | 01:02 PM
When making the adjustments do I need to have the car jacked up or can do it with the wheels on the ground.
Old Jun 28, 2008 | 02:36 PM
99ssleeper's Avatar
if you can make adjustments with it on the ground, go for it. but youll probably have to lift the car up so you can get at it easier. i had to lift it up.
Old Jun 28, 2008 | 02:38 PM
Viper's Avatar
Most have to lift it up to get enough droop to get your hand in there.
Thanks I just wasnt sure if I had to have the wieght of the wheels.
