shorten sway bar end links when car is lowered?
Old 10-17-2008, 01:45 PM
cals400ex's Avatar
i would assume you are supposed to use a different one if bmr has them.
Old 10-17-2008, 03:57 PM
benoh's Avatar
I've checked their website and they only have the regular swaybar endlinks posted.
Front = 19-409
Rear bushings + endlinks = 7-1129
... if they do sell end links for lowered cars, how much shorter are they? What are the specs of these endlinks? Has anyone ordered these?
Old 10-17-2008, 06:58 PM
sneaky7980's Avatar
Originally Posted by benoh
... ran across this and very curious to what the final verdict might be on using different height endlinks for a lowered car.
So, what's the final verdict? Duralast endlinks? ... or do we even need to use a different sized endlink if your car is lowered?
I guess that if your sway bar is parallel to the ground then your good. At least that's what im going by. If it's not then you would have to research and find on that gets it into the right postion or mod your old one.
I had to buy new ones regardless since both of mine broke. They would make a better starting point of your going to do some fabrication. I'll have to take a pic of at my duralasts with my eibach pros and let you be the judge.
Old 10-18-2008, 09:37 AM
kraemer94's Avatar
I would like to know the answer to this as well as I'm about to install Konis and springs.
Old 10-18-2008, 09:40 AM
kraemer94's Avatar
Found this:
https://ls1tech.com/forums/showpost....7&postcount=10
Quick Reply: shorten sway bar end links when car is lowered?
