If your educated in the way of the torque arm come in!
#41
Uhh not realy, its still on the car. I would say probably not though. The reason i didnt use the safty wire, is because i didnt have a problem with the bolts Turning and backing out, they just simply RIP out. So i cant drill through, can i retap the threads maybe? What the hell am i to do buy a new rear end?
If the threads are shot there is little else you can do but to drill them out and go the next bolt size up.....
#44
![Bigun2](https://ls1tech.com/forums/images/smilies2/bigun2.gif)
Later down the road i can relocate it, and exchange it for an adjustable. I think this will help since it will be just like a factory set up, and nowhere for me to F*ck anything up.
On a good note the torque arm is now for sale!
#48
Ok guys Ive got it on stands, getting ready to tap the holes, im going to just put my new 60# in to, port the Maf, TB, change wires, plugs, TB Bypass, Fuel pump, FPR and do some MAJOR cleaning while im at all this.
Here are some pics...I got a pic of the bind the DS and rear are in
I took off the torque arm, and it didnt move so that appears to be the angle it is in durring driving.....Hince the retaded vibrations and noise.
Also got a pic of the bolt that is used in the top front hole on the rear. compared to the other holes. Do i need to tap the other holes that big? That bolt is massive compared to the others.
On another note, i found this part with the electrical connection still connected, but that was the only thing connected. the hoses that apear to connect there are absent. It was found on the DS of the intake manfold. Does anyone know its purpose?
Also How do you disconnect the fuel line from the fuel rails?
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
#49
Well here is an update, I got a stock torque arm off of a v6 auto car, and stuck it in there. Havent had a problem with it since....anyone know what that thing is that i attached a pic of before?
