lower control arms
Step #1, Throw the Lakewoods in the trash....
1.Set the body on jackstands.
2.Leave a jack under the rear axle, let the axle hang, don't jack it up unless you need to move it slightly to line it up (you probably won't need the jack).
3.Remove one at a time.
4.Put the bolt through the body first(it is the hardest to reach and install).
5.Have Zane push (or pull) the rear axle into place to get the bolt hole lined up. A standard (straight blade) screwdriver may help to pry the bushing into place once you get it close, just slide it in the hole and use it to "lever" the bushing into the correct location, once it is lined up, put in the bolt.
6. Lift the rear of the vehicle by the axle, set jackstands under the axle (and the body for safety) and torque the bolts on the LCA's. You want the seight on the axle when you torque them or they will likley make noise when you drive over bumps.
7.Send Jason a check....
That's all there is to it.
