anti squeek, anti garbage suspension thread
BTW, If you search your local store, or maybe rockauto, there's a "walker" brand exhaust mount that's a more "solid" design that replaces this mount. I believe it's rubber, but it sure did eliminate lots of the "dueling bedsprings" and "clunk junk" noise.
This is it (walker part #35460):
They're usually 3 to 5 dollars US and are usually very easy to source.
I'd say with getting the Strano bar, try to install both front and rear at the same time if you plan on doing "spirited driving." While Sam's 35/22 combo is ideal for handling, paring the stock 30mm with the rear 22mm can cause for some real nasty, unpredictable handling, if you're not careful.
btw, sorry for asking another question...
Have you checked the rear springs? Are they seated properly, and are the isolators properly installed?
Also, I'm not too sure if you do this or not, but for the rear, I usually do the "bounce" or "jounce" test while the car is safely parked and have someone with some sort of good hearing and/or sound detection equipment (e.g. a sensitive microphone, or likewise) to hunt down wierd creeks and rattles as the other person "jounces."
Just some ideas.
Just some ideas.
