boxed sfc's make a huge difference?
also, an adj. PHB does NOTHING for launching or handling. its to re-center the rear end after lowering the car. if you put new shocks/springs on, then youll need it. if you plan on doing it later on, then still get the adj. PHB so you can align the rear later. it does nothing for drag racing, other then making sure the rear is lined up.
They are both equal in strength! It just all depends on what you have access to! If you have a welder....go with the weld on! If not The bolt on are just a good. If you have any other questions I will be glad to help!
Thanks again!
Brad
Hope that helps!
Ryan
If I can help anymore please ask. Thank you!
Ryan
