QA1s with Eibach Pro-Kit
Old Sep 11, 2003 | 05:27 PM
NX†C's Avatar
Default QA1s with Eibach Pro-Kit
anyone done this or still running it...just curious as to its potential as a combination or if anyone had done it and would not recommend it.
Thanks for your thoughts and input.
Old Sep 12, 2003 | 11:46 AM
Bad Blu Formula's Avatar
Default Re: QA1s with Eibach Pro-Kit
ttt
Old Sep 12, 2003 | 10:27 PM
mics2fbodies's Avatar
I have,although I'm using the hal springs in front at the moment.Car feels fine.
Old Sep 14, 2003 | 09:34 AM
BYBYC5's Avatar
*Bad Trader*
TTT id like to know as well, can the pro kit springs be used up front with out modifing the Hal shock? i wanna run hal fronts with the prokit fronts and a bilstein w/pro kit in the rear...
Old Sep 14, 2003 | 11:36 PM
Z-Rated's Avatar
Im pretty sure its the same as stock, why wouldnt it be? think about it, its an inch shorter. Therefore you just have to get the seats modified to fit. Being that its a coilover I really see no problem using the prokit. Unless the spring rate is too tight, but not enough to worry about.
Old Sep 15, 2003 | 04:32 AM
NX†C's Avatar
I'm not so much worried about it "working" per say; I can modify most things to fit...what I'm more interested in is actually ride quality, drivability and what shys people away from such a combination and if any had done this what factors warranted the switch. Again thanks.
Old Sep 15, 2003 | 09:45 AM
CamM's Avatar
Hals do not need modified with Eibachs, only the front stock shock perch will need to be cut. ThunderRacing sells the modified perches which is worth it IMO.
I have this exact setup with no problems.
Make sure you keep the Hals front shock settings to 5 or higher or the front gets too bouncy.
Old Sep 16, 2003 | 10:31 AM
1fastWS6's Avatar
I have the QA1's up front with Granatelli springs. I set them on 6 for daily driving and 1 or 2 at the drag strip. They ride very nice on the street set on 6.
I'm very happy with mine! It's a good street/track combo.
Old Sep 23, 2003 | 05:31 PM
z289899's Avatar
I'm thinking of doing a sinilar set up, does anyone know where those modified spring perches are, I can't seem to find them?
Old Sep 23, 2003 | 07:46 PM
TexassTA's Avatar
Thunder Racing has them. Look to your right and click on Thunder racing.
Old Sep 23, 2003 | 07:57 PM
z289899's Avatar
Yeah, I looked before but didn't see them, but found them now thanks.
