What do you guys think of these LCA's?
http://nh.craigslist.org/pts/864284428.html
brand new and $50 on CL. Opinions? Also what do you guys recommend for LCA relocation brackets for these? Thanks guys
LS1Tech Premium Sponsor
Hello, i would recommend our bolt on relocation brackets. They are a direct bolt on and are laser cut and formed out of 3/16" cold rolled steel.
http://www.bmrfabrication.com/F4.htm
i didnt see a brand name, so you could be buying a weak material which is dangerous. also it looked like double rod ended LCA which is gonna be rough on a daily driver (i know for fact, cause i have rod/rod on my DD). i would say you are safer going with a brand name for suspension parts. anyone of our sponsors will suffice. NEVER go cheap on something like suspension, it could be dangerous.
This is a good point. Stick with one of the sponsors here for ctrl arms. UMI and BMR makes some good ones. Poly/rod ctrl arms seem to be a good balance for street/performance since the rod end allows free movement while the poly end won't transmit as much noise.
If you have any questions regarding our product please ask and I will be glad to help. Below I posted a link to view our control arms.
http://www.umiperformance.com/produc...ategory_id=106
Thank you!
Ryan
Thank you!
Ryan
Not knocking BMR's arms, I just don't have any experience with them.
I had BMR's bolt-in LCA relocation brackets when I had my 10-bolt. They were very easy to install and helped out a lot with some wheelhop issues I was having.
-Mike
