What cam should I get?
I don't know what cam to get with my setup. I have a 1999 Firehawk and this is my setup. 346ci with LS6 heads. I have a 3000-3500 stall with 3.73 gears. I have air lid, hooker long tubes, 3 inch y pipe and SLP loudmouth. I have an extra set of REV racing dual valve springs that are good for over .600 lift so i can do what ever you all recommend. What cam would be good for my setup? I drive it every other day so its not my daily driver. My brother has a G5 cam that comes with specs 228/232 Duration & 588/574 Lift at 114 Lobe Seperation. I like how this cam drives. It doesnt sound like a big cam at all. Let me know what would work good with my setup. I want to get the most out of my stall and 3.73 gears. Any info would help.
I have a 228/236 .588/.601 114lsa cam with my 3600 stall. It works well but I would def go with a tighter lsa. There are sooo many cams out there that are proven, good luck with the decision.
with 373s you could go with an MS3. However you would be faster in a quarter mile with a 230 or 236 cam. Depends how loose or tight your converter is. But if you enjoy hauling *** on the highway yhou may like the MS3 more. I you had better springs i would recoment an LSR or XFI cam, but XER is your best bet.
i can vouch for the ms3. i buddy of mine with this cam and bolt ons only no 243's. went 11.95 on a mickey drag radial. and he is spraying and has gone 11.1 on a 100 shot. ans is ONLY 2500 stall.
