**Pavlock Performance Stage 2 Street Assassin Package!**
We are finishing up our Stage 2 Street Assassin Package. This package consists of our hand ported/flow tested heads. The customer wanted to run stock valves so we cut a fresh valve job and got the heads to flow 303 cfm at .600 lift from a 241 casting and absolutely ZERO turbulence all the way through .900 lift. This is a stock 2.00in valve not an upgraded 2.02 or 2.055in valve. You would see a greater increase with the larger valves. Each port is within 2cfm of each other unlike a lot of the CNC heads that we have had on our flow bench. We then matched the heads with a custom comp cam. We have a few miscellaneous parts to install and then will have it on the dyno. Here is a video clip of the car once we got it running enjoy
price? most curious about how much you charge to remove, port, and reinstall the heads.... but what is the cost of that package including cam?
that cam sounds GOOD!!
Bryan,
I appreciate your time with me over the phone today. Before I make my decision on who to go with, I will be driving an hour from south houston to consult you all in person in the next month or two. Your prices were very fair. Thanks again
