When is Chevy finally going to up the hp in the Z06???
Old 10-31-2009, 01:47 AM
TexasVortexx's Avatar
Originally Posted by 7camaro7
doesn't the supercharger up the liters?
No but it does create a strong vacumn to better suck the spent air/fuel ratio from the combustion chamber
TexasVortexx is offline
Old 10-31-2009, 02:00 AM
7camaro7's Avatar
thanks for explaining that...I get what you mean anyway. I'd say it does not creat a vacuum though. A vacuum is low pressure. Low pressure would naturally be the atmosphere. The supercharger creates a higher pressure inside the cylinders. When the exhaust valve opens more exhaust comes out than when naturally aspirated.
Is that what you're trying to say?
or one side of the sc is a vacuum and the other side blows into the engine. I gotcha
7camaro7 is offline
Old 10-31-2009, 02:05 AM
7camaro7's Avatar
Originally Posted by THE BLACK WIDOW
you guys are starting to hurt my feelings
7camaro7 is offline
Old 10-31-2009, 02:17 AM
winters97gt's Avatar
I really don't see the car needing more power. 122+stock trap speeds? From my experience with my SC'd mustangs, 120mph is about all you can really handle on the street. More than that, you are just modulating/feathering the clutch and throttle, and really can't use all the power unless the roads are clear and safe.
505 is plenty, if more needed, then mod it.
winters97gt is offline
Old 10-31-2009, 02:20 AM
lemons12's Avatar
Nowadays 120mph isn't anything out of the norm..
Anybody somewhat serious about racing can trap 125+mph.. Hell, H/C sprayed ls1s trap 130+mph.. Ported/pullied cobras are right around there..
Plus, its fun messing with bikes!
lemons12 is offline
Old 10-31-2009, 07:13 AM
HTX
HTX's Avatar
yeah but the cars trapping 130+ are like 9 second cars. 120 is still fast for a street car. Especially a legal car.
HTX is offline
Old 10-31-2009, 07:17 AM
HTX
HTX's Avatar
Originally Posted by ZMONSTER!
? I dont know a whole lot about vett's, just aint my thing, but isn't the ls7 7L and the ls9 6? Im pretty sure they aren't in the same engine family, IE ls1 and ls6, ls2 and ls7, then the ls3 and ls9.
maybe i should research before i post. Considering where i read my information (car and driver) i should have looked more into it.
on another note... Super chargers have a displacement all on their own. They do not really add to the displacement of the motor. I believe that the displacement of a motor is rated in the short block.
HTX is offline
Old 10-31-2009, 07:18 AM
streetassasin's Avatar
thats the point
streetassasin is offline
Old 10-31-2009, 08:18 AM
LS1Tech Co-Founder
Nine Ball's Avatar
I'm so ashamed of all the misinformation going on in this thread. Some of you should light your keyboards on fire in order to avoid using them.
Thanks
Nine Ball is offline
Old 10-31-2009, 08:23 AM
JeaneZ28's Avatar
but the sc's are sometimes rated in liters, though right?
I figure with higher compression in the cylinders, it is like cramming more air and fuel in than usual which makes more liters. The only reason you're getting extra power from the sc is because of extra fuel and air being forced into the cylinders.
A stroker kit does not make the block bigger, but it makes the strokes longer and I'd also say liters and ci's. With FI it seems logical to me to say the liters go up.
No matter how big a given foot is, no matter how big or small the shoe is, the foot will remain the same size no matter how you get it into the shoe. That's how I'm thinking of it.
The displacement isn't measured by how much space is in the cylinder. Its measured by how much space is between top dead center and bottom dead center of the pistons. A stroker kit ups the displacement by making the piston able to come down more in the cylinder.
JeaneZ28 is offline
Old 10-31-2009, 08:52 AM
RCC
RCC's Avatar
Originally Posted by HTX
The LS7 is in every way superior to the LS3. The ZR1 has an LS9, which is the forged and super charged version of the LS7.
You might want to check some facts before posting. The LS9(ZR1) uses the LS3 as a base and not the LS7. As far as LS7 superiority over the LS3, stock motor to stock motor yes it makes more power. For modding reasons the LS3 beats the LS7 hands down everytime- thats why the LS9 starts as a LS3 and not the LS7. Ls7's are truly awesome motors but their comp. ratios and pistons do lend well to making other than N/A horsepower.
RCC is offline
Old 10-31-2009, 10:16 AM
  #32
06colorado's Avatar
Correct, i believe they only changed the pistons for a lower compession for the supercharged ls9. The ls9 has the the same bore, stroke, and even same designed heads, they just used a better source of aluminum for the block and heads, and of course the forged internals
06colorado is offline
Old 10-31-2009, 10:44 AM
  #33
Doomsday's Avatar
LTx > LSx done.
Doomsday is offline
Old 10-31-2009, 11:05 AM
  #34
zblackz28's Avatar
So yeah I think I understand what ya'll are saying now, you dont have to be poor to be dumb as hell!
and that superchargers are for getting all those pesky hp's made from just adding a supercharger to the Ls7, because thats what happened...all this new info makes my head hurt!
zblackz28 is offline
Old 10-31-2009, 11:56 AM
  #35
Thanks
Lol.... having too much fun to do that
Old 10-31-2009, 02:03 PM
  #36
carlos sauceda's Avatar
you see i told you lol a ls3 is better for modding and that it was used in the zr1 hahaha...
carlos sauceda is offline
Old 10-31-2009, 03:11 PM
  #37
00fastta's Avatar
Originally Posted by Doomsday
LTx > LSx done.
Fail...
This thread fails
00fastta is offline
Old 10-31-2009, 04:44 PM
  #38
HTX
HTX's Avatar
it may be used in the zr1 and i have already admited i posted bad information on that.
however i dont see how an ls3 at half the price and almost a full liter smaller than the ls7 has more potential. are we talkin FI or NA?
HTX is offline
Old 10-31-2009, 04:53 PM
  #39
bballr4567's Avatar
Only thing I see happening is GM going direct injection on all of their V8 motors.
Does anybody know WHY the LS3 block was used?? Or...... are people just going to keep saying that its better because its in the ZR1?
bballr4567 is offline
Old 10-31-2009, 05:04 PM
  #40
JeaneZ28's Avatar
The main reason they used the LS3 is do to the thickness. Here is a video explaining it.
http://www.autoblog.com/2008/03/04/v...r1-ls9-engine/
JeaneZ28 is offline
