What in the hell noise is this?
Old Jan 14, 2010 | 01:09 PM
Shackleford's Avatar
Default What in the hell noise is this?
Just got back the car from the transmission shop. I had it rebuilt. I don't suspect foul play. However, I just noticed the noise last night. Maybe there's a connection. I don't know.
What could this knock/rattle/whatever be?
http://www.youtube.com/watch?v=lCOEmL9_uUc
Old Jan 14, 2010 | 01:31 PM
FIREHAWK #07's Avatar
just bought a truck; got the firehawk for sale. Let me know.
Old Jan 14, 2010 | 01:42 PM
03Sssnake's Avatar
Sounds like a flexplate to me. Is the motor running fine other than that noise, good oil pressure etc? Get the car on some ramps, most of the noise should come from the bell housing and back of the motor if its the flexplate..
Old Jan 14, 2010 | 01:51 PM
98silvertacrbn's Avatar
torque converter bolts?
Old Jan 14, 2010 | 02:26 PM
carlos sauceda's Avatar
damm u just realized that loud *** noise?? lmao
Old Jan 14, 2010 | 02:29 PM
Didn't start till last night.
Old Jan 14, 2010 | 02:44 PM
oh that sucks... maybe u should go get ur money back or tell them to rebuilt that hoe with better parts
Old Jan 14, 2010 | 02:46 PM
Well, apparently, it's the water pump. That would explain the leaking coolant I saw last night. It did seem like the noise was coming from the front of the engine and the transmission guy noticed it, too, but I just wanted to make sure it wasn't transmission-related.
How different is replacing the LS1 water pump than on the LT1? Is it easier?
Old Jan 14, 2010 | 03:01 PM
whitehooptie's Avatar
You have to pull the belt About the hardest thing.
Old Jan 14, 2010 | 03:09 PM
chupr0kabra's Avatar
VERY easy. Just make sure you get new gaskets along with the pump. Part number 12559271.
-Mike
Old Jan 14, 2010 | 03:11 PM
-Mike
Doesn't the water pump gasket usually come with a new/rebuilt water pump?
Old Jan 14, 2010 | 03:32 PM
Not sure. I've never replaced one, but I had to remove/re-install one when I swapped oil pumps on my Z28. For that process, I made sure to get new gaskets.
-Mike
Old Jan 14, 2010 | 03:56 PM
redz_02's Avatar
Good word of wise, always get new gaskets when replacing parts.
Old Jan 14, 2010 | 11:25 PM
02Z28LS1's Avatar
yup, better to have too many than not enough....and if the new part does come with one, you can always either return the extra or keep it as a spare
