anyone work for ADT or have a friend that does??
does anyone here work for ADT or havea friend that does? I am looking to add some sensors to my alarm and have a few questions for an ADT employee.
I installed for a long time, what do you need to know? Adding sensors doesn't have to go through the alarm company, they are all just wired in series and you can just splice into the existing sensor wires, as long as you do it IN SERIES! If you do it parallel both sensors would have to open for the alarm to trigger.
If that doesn't answer the question let me know.
I have been installing for a bit. What system do you have. look a panel inside security box. What all do you want to add? May say on keypad but may just say ADT? Problem with ADT and other big companies is they lock out the programing so you have to go thru them.
I am hoping someone may know the codes or know a way aroudn them. I read through my contract with ADT and it didnt say anything about not doing that.
When you add sensors you will have to add the zones not only on your system, but must also update your zone list with the monitoring station. That way when your system trips the new zones, the monitoring station will know what they are in order to dispatch. May be able to hard wire reset panel and reprogram whole system. Need to know what panel type they installed?
