waterpump change lt1
Old Mar 21, 2010 | 06:37 PM
t/afrom504's Avatar
Default waterpump change lt1
how much should a shop charge to change the waterpump on a lt1? so far i have gotten a $350 quote including parts and labor and i think thats even too high
Old Mar 21, 2010 | 06:44 PM
Jake_the_Snake's Avatar
i remember i paid 200 for labor, and about 80 for the part plus antifreeze and a new thermostat
Old Mar 21, 2010 | 07:00 PM
zamora7's Avatar
Do it yourself, its not that hard. I did it in my driveway.
Old Mar 21, 2010 | 07:15 PM
b00ya's Avatar
doit yourself, its not hard at all, just gotta be careful to not dump coolant on the opti.
Old Mar 21, 2010 | 08:24 PM
t/afrom504's Avatar
well i was thinkin of doing it myself since i know how to get to it BUT Im just not sure about it unless someone from here wants to do it for me or give me step by step directions.
Old Mar 22, 2010 | 12:14 PM
they're right, it doesnt look too difficult. i had mine done at a shop cuz i had to go to work and had no time to work on it before i had to go to school the next day. not to mention i had just finished replacing the radiator, hoses, etc and the thought of smelling coolant again made me gag lol
Old Mar 22, 2010 | 12:52 PM
FireHawk178's Avatar
I changed one on a '97 Z I had and it wasn't hard at all.
Old Mar 22, 2010 | 04:13 PM
gunter96ws6's Avatar
ive done it on the side of the road with minimal tools. you can do it buddy.
Old Mar 22, 2010 | 08:56 PM
whitehooptie's Avatar
If you have an underdrive pulley, all you need is a 3/8th's wratchet, 14mm deepsocket, 2" extension, 14mm shallow socket, water pump gaskets and silicone. Don't even have to pull the belt. Oh and some water/antifreeze.
Old Mar 23, 2010 | 06:48 PM
I8ASaleen's Avatar
It's relatively easy if you have the tools and a clean place to work. Just make sure you drain the whole system before you take out the pump or you'll have antifreeze all over the opti.
Old Mar 23, 2010 | 07:36 PM
mitchntx's Avatar
If it attaches to the block or heads, it's SAE. In this case, it's a 9/16. 14mm is close, but it's not a metric bolt.
Just to be clear ...
The power steering pump attaches with metric bolts because it bolts to the accessory bracket. The accessory bracket attaches to the block with SAE bolts.
Old Mar 23, 2010 | 10:43 PM
I guess mine are wore out or something. I have to almost hammer a 9/16ths on.
Old Mar 24, 2010 | 06:37 AM
mitchntx's Avatar
I've had a lot of LT1s roll through my shop over the last couple years. I can't tell you how many metric bolts I've seen galled into aluminum heads.
Old Mar 24, 2010 | 01:31 PM
95zpro's Avatar
http://www.corvetteactioncenter.com/...optispark.html
Old Mar 24, 2010 | 04:19 PM
chavez885's Avatar
1. Remove intake
2. Drain Coolant
3. Pull off serpentine belt (more room)
4. Protect opti
5. Disconnect 6 bolts holding pump
6. Replace pump and coolant
Old Mar 24, 2010 | 09:00 PM
Well mine are the original ones that came on the car 16 years ago. But I know what you mean. I used to get my tranny bolts mixed up with my bellhousing bolts and would wonder wtf. Then I learned me the difference between them thar bolts.
Old Mar 24, 2010 | 09:29 PM
BizZzatch350's Avatar
Moderator
ARP makes a really nice engine bolt kit that I used, makes life a lot easier.
Old Mar 24, 2010 | 09:49 PM
mitchntx's Avatar
LOL ... I feel your pain.
