Stroker LS1
Old Apr 6, 2010 | 02:26 PM
rtrygstad's Avatar
Default Stroker LS1
I've been considering building a 383 LS1 but have been told that for a daily driver stroked LS motors are a bad idea due to the piston coming out of the bottom of the cylinder lining. Does anyone drive a stroked LS daily and what do they think of it? Thanks!
Old Apr 6, 2010 | 02:38 PM
Juicy J's Avatar
A 383 is considered the "safe" limit for an ls1 without resleeving. 383 strokers however are not that popular because there are much better options out there.
Old Apr 6, 2010 | 02:49 PM
rtrygstad's Avatar
Well I already have an ls1 and don't really have the money to get another block. It needs to be rebuild so I figured I might as well stroke it while I have the motor out and taken apart.
Old Apr 6, 2010 | 03:05 PM
Pheonix's Avatar
I daily drive mine with no problems, putting 460rwhp NA. Mine was built back in 99' so there werent any options out there.
Old Apr 6, 2010 | 06:03 PM
rtrygstad's Avatar
How many miles have you put on the motor since you made it a 383? Nice TA by the way.
Old Apr 6, 2010 | 06:36 PM
Pheonix's Avatar
Thanks, i say about 15k. It sat for yrs.
Old Apr 6, 2010 | 09:09 PM
rtrygstad's Avatar
ok thats for the input!
Old Apr 7, 2010 | 07:43 AM
pimpinpaco's Avatar
I being thinking on doing mine a 383 stroker too. What do you think is a better option?
Old Apr 7, 2010 | 08:01 AM
Juicy J's Avatar
A 402ci is not much more expensive, and the better option for the price, but you would not be able to use the LS1 block unless it was resleeved. You could do either a LQ4, or LQ9 iron block, or an LS2 aluminum block.
I am not saying a 383 is bad, people get good numbers out of them. All I am saying is if you are spending the money, why not spend a little more and get some extra CI.
Old Apr 7, 2010 | 10:23 PM
rtrygstad's Avatar
I guess I could jack my brothers LS2!
Old Apr 7, 2010 | 11:43 PM
sway99bird's Avatar
I have a 383 but don't have that many miles on it .........
And the reason I went with a 383 is that I found all the parts for a good price and couldn't pass it up so that's what I have a 383 . I wanted to go bigger CI but I like my 383 so far not sure if i'm going to boost or spray..........
Sway
Old Apr 8, 2010 | 01:28 PM
BAD2000TA's Avatar
I daily drive my 383. I have about 14,000 miles on it so far. I built a 383 because I got an LS6 short-block cheap, way cheaper than trying to find a decent LS2 block (plus I was able to sell the crank, rods and pistons!). Eric at HKE hooked me up on the machining and balancing and good prices on the crank and rods. Pistons came from Scoggins, cam from MTI (before they closed). I'm very happy with it.
Old Apr 8, 2010 | 05:46 PM
rtrygstad's Avatar
What kind of power do you make? and What gear ratio?
