Good heads/cam setup or supercharger?
Old 07-02-2010, 11:19 PM
retardedpenguin's Avatar
Default Good heads/cam setup or supercharger?
I am picking up an 81 Trans Am Tuesday and I want to drop an LS1 in it. No bull **** this time lol, I am actually going to restore one for once. But what would a good set up be? I would like people to recommend their own set ups and dyno numbers. Is $2500 a good budget for 450rwhp? I would like a choppy hell raising cam.
Or should I get a procharger or supercharger for the 400 in it? I have always wanted a car with a big roots blower sticking through the hood. I figured after everything was said and done I would have $5000 in the ls1/t56, and I am thinking a supercharger, carbs etc would be the same price.
Old 07-03-2010, 12:25 AM
happysem's Avatar
Just remember, boost gets expensive, FAST.
For 2500, I would do heads/cam with the LS1.
Old 07-03-2010, 12:50 AM
MR2liter's Avatar
317 heads and a high lsa cam. 115-117!!!!!
Old 07-03-2010, 06:46 PM
I found a couple turbo kits, any opinions? I have to get a fuel pump and all that anyways.
Old 07-03-2010, 07:00 PM
Ws6kid.'s Avatar
i second the post saying boost gets expensive fast
it al depends how fast you really want to go
if your looking for a car quick but not crazy fast
go heads and cam? (anyways if you get good heads they could be used again if you go boost?)
Old 07-03-2010, 08:38 PM
I found a kit for $2400 without the turbo, I figure it would be cooler and easier to install.
Old 07-03-2010, 09:11 PM
westtexasbuff's Avatar
Yeah but then you're going to have to upgrade your fuel system, injectors and at least a 255 Walbro. Beef up your tranny, I'm assuming M6? And what rear end is in that? 10 bolt?
I would honestly just to a heads and cam, much more reliable than a cheap turbo setup. 450 would be tough with your budget, but you can get close to that. Get some ported 243s, and a MS3, or something in the 23x/23x .60x/.60x range. Port your LS6 intake (assuming the LS1 is an 01+). And get it tuned by someone like Gforce, I'm sure you can get close to your goals. I have a friend who made 450 cam only with a MS3.
Old 07-03-2010, 09:17 PM
ex-SS-ve's Avatar
Heads, cam and 100 shot. Just heads n cam would break that budget
Old 07-04-2010, 12:28 AM
SnIpEz's Avatar
A turbo is harder to install than a procharger (a procharger is a supercharger btw ;]) Procharger's are centrifugal, not roots, but you may have been referring to other types in your first post. If you're budget is $2500, forget going FI. Link to the kit for $2400 plz? I'd like to see it. Going FI means so much more to go with it. The whole fueling system (Im speaking from the perspective of a Procharger, since that's what I've researched) is several thousand alone, plus a new rear end to hold up the power, plus a new tranny to also withstand the power, plus a forged bottom end if you want to raise that boost level above 10 PSI. These FI setups also work better with Cammed and head setups, good heads run over 2k alone sadly, and a cam is another 400-500, plus supporting accessories.
A D1SC Procharger is 6500k for the whole system, an F-1C (my blower of choice) is 7500. If you call the right ppl (cant say who, dont want to screw them over by saying it publicly on the forum, PM if you want to know) you can get a D1SC complete brand new for 5k and an F-1C for 5500. A really good turbo should cost the same if not more than a Procharger, and a lot of turbo owners would agree, installing and maintaining them is a bitch.
What's the most you'll put into this?
Old 07-04-2010, 10:50 AM
I am hoping 3500 to 4000 MAX with everything, as it it's in the car and running plus the cost of the engine. I found an 01 ls1 t56 for $2000 so that's taken care of.
https://ls1tech.com/forums/parts-cla...l#post13553483
Old 07-04-2010, 12:07 PM
brian_rs/ss's Avatar
if you had an ls6 i would say boost it. but i say fix all the restrictions of the ls1 first. ie: h/c/i/valve train/fuel/exhaust....then see if you still want some boost. or if you can afford it.
Old 07-04-2010, 12:10 PM
Ok. Also have to factor in that $6500 can go a long way for the 400 in there now.
Old 07-04-2010, 01:08 PM
SnIpEz's Avatar
All you will need is a turbo, and fuel system.
There is no turbo, just the piping etc. And the fuel system is another couple of thousand. if 3500-5000 MAX is the budget, ditch any FI plans
Might be better off doing something with the 400
Old 07-04-2010, 02:19 PM
400's are bad *** little motors. my dad did amazing things with his back in the 70's with his 67 gto ram air.
Old 07-04-2010, 03:14 PM
texas94z's Avatar
Leave the true Pontiac motor in the true Pontiac car. You don't have a Chevrolet, you have a REAL Pontiac. Don't disrespect the brand. The only way id drop a LS1 in the car if you plan on completely modernizing the car. I think 400s are way cooler than LS1s anyways, however LS3/7/9s are a different story.
Old 07-04-2010, 03:32 PM
I guess if you think 6 mpg is cool too lol, I have had one before.
Also this is pretty much exacty what it's going to look like except with the 17 inch snowflakes.
Old 07-04-2010, 04:41 PM
call me crazy but i actually like those^ rims. i know most don't.
Old 07-04-2010, 05:23 PM
I like them too, they look like Fikse FM10s sorta...
Old 07-04-2010, 05:39 PM
sway99bird's Avatar
I love those rims
Old 07-04-2010, 05:46 PM
I do too, but they are $3,000. Considering it though.
Quick Reply: Good heads/cam setup or supercharger?
