car wont start
car wont start
My car wont start after i swapped headers last night, i checked my starter wire to see if it was shorting out on the header but no dice and the battery is brand new as of this morning.
any ideas?
thanks for the help
any ideas?
thanks for the help
cables are tight. i turn the key everything lights up like it should then disappears then once i turn the key to crank it over i hear a single click then everything dies in a time span of 1 second. if i try to turn it over again nothing happens as if the battery is totally dead
If a fuse is blown he wont get the click sound.. The click is the result of the voltage dropping once the current is drawn.. The issue is either a loose starter connection or lose cables or a loose ground
thanks for all the help guys it was the battery connection, a coke later and it fired but only for a second then my dumbass remembered to plug the hole on the intake. The car runs fine now just finishing some odds and ends currently
