Anoyone know anything about this car? Houston
Old 04-28-2011, 01:10 PM
5w20's Avatar
Originally Posted by strokerblackhawk
uuummm i could be wrong but on an ls1 if you throw a 4 inch crank in it comes out to a 383 on an LQ9 6.0 the cylinder bore is bigger which with a 4 inch crank should make it a 408, ls2 with a 4 inch crank i believe is 402 so if it has an ls1 unless he re-sleeved it and punched it out i think hes bsing you. i could be wrong though.
move around and don't look back
Originally Posted by KidFromThePast
There is no markings to tell of its a 6 liter block?
not easily visible
Old 04-28-2011, 01:16 PM
Ravenous T\A's Avatar
I bet its a 5.3L with a cam and his old heads cause he blew the 1st motor
Old 04-28-2011, 02:03 PM
5 Liter Eater's Avatar
It's a strocker! How could you go wrong?
Old 04-28-2011, 02:08 PM
strokerblackhawk's Avatar
not easily visible
? what does that mean?
5w20's Avatar
Listen here, you missed the most obvious. He is sittin' on dem THANGS!!!!
Old 04-28-2011, 02:10 PM
5w20's Avatar
¡ it means that what you said is correct, OP needs to move around (get away from) and don't look back (pass, on to the next one)!
Old 04-28-2011, 02:12 PM
aahhh now i feel like an *** for not knowing that lolol
Old 04-28-2011, 02:55 PM
BrianSF-GA's Avatar
Originally Posted by Bad Chad
Put it on a Dyno and see what it makes...
If you are seriously interested, I would say this suggestion is your best bet.
Old 04-28-2011, 03:05 PM
ex-SS-ve's Avatar
offer him 3k$ for it. if he dont take it move on to the next one. 98s are straight up doo doo!
Old 04-28-2011, 03:06 PM
KidFromThePast's Avatar
Yah.. wished there was a good give away that shows its a 408 .
Truthfully, I'm trading him something worth alot less than the car.
It has quite a bit of suspension work done to it too. All UMI stuff.
Old 04-28-2011, 03:14 PM
aren't the computers an ******* to try and tune also i heard there was a lot less stuff you can change on the 98 computers
Old 04-28-2011, 03:24 PM
  #32
drago1217's Avatar
IF it is a 408 and IF it was sleeved to have bigger bore and a crank for stroke in an ls1 I'd probably pass on it because of the wall thickness on an ls1. It would just be a matter of time where you would have problems keeping the block cool. my .02. why are you in the market for another anyways i like your camaro much better than that.
Old 04-28-2011, 03:26 PM
  #33
brian_rs/ss's Avatar
lol this is a winnar!
jk it's a tarp. gtfo before the tie fighters show up.
Old 04-28-2011, 06:52 PM
  #34
5w20's Avatar
you don't have a clue on sleeved blocks. next time refrain from saying anything.
Old 04-28-2011, 06:58 PM
  #35
drago1217's Avatar
Your right what was I thinking
Old 04-28-2011, 07:13 PM
  #36
baalic's Avatar
@5w20. A sleeved ls1 408 looks IMO like it's a a time bomb from all the ones I've seen... In that respect I myself want nothing to do with one..
Old 04-28-2011, 07:24 PM
  #37
drago1217's Avatar
Iron block great. Aluminum block no thank you. Wall thickness after resleeve is not something I would desire to have. Even on an Ls2 4" crank bored. 60 over is a 402 right. I might be wrong. Can it be done ....yes. would I take that chance
....no personal preference I guess. Now if like I said it was an iron 6.0 to start I'd do it
Old 04-28-2011, 07:32 PM
  #38
FireHawk178's Avatar
Originally Posted by 02CamaroSSLE
thing is def donked out! lol wheels are hideous! and his typing confused the hell outta me. he has a ported and polished cam though so i think you'll be alright! hahaha
x2. I was going to ask if CL charges for punctuation.
Old 04-28-2011, 07:58 PM
  #39
InsuranceGuy's Avatar
What you need is a cubic inch tester. Sanctioning bodies
use them to determine engine size rather then requiring
head removal.
http://www.powerhouseproducts.com/ph...o-670-c-i.html
Old 04-28-2011, 08:11 PM
  #40
5w20's Avatar
<---if you weren't so busy maybe you would know.
http://www.erlperformance.com/gm-ls-...-block-sleeved
you must be one of those that iron is god
Quick Reply: Anoyone know anything about this car? Houston
