What cam should I get? PLEASE HELP!
It's going in a 2002 camaro with a stock ls1 bottom end (346) with the following mods: built 4L60 with a yank ss 3800, full BMR suspension, 3:73 rear gears, Stage II heads with 2.02/1.575 valves, fast 90 intake, 92mm nick williams throttle body, 42 pound injectors, comp pushrods, comp dual springs (pt# 26921-kit) with comp titantium retainers, terra 1.7:1 rockers, Mac 1.75 mid headers, 4" exhaust system, it has a Lunati cam in it now (222/218 581/562 LSA: 114 adv. +2 degrees reverse split). This is not my dd car. I drive the car on the weekend and take it to the track. I ran a 7.70 at 89.9 mph, with a 1.7 60ft. on street tires. I would like a nasty idle, with a good gain in power. I'm thinking something in a 235 dur and 600 lift on a 112. What does everyone think I should put in it? Thanks for any imput.
Call Thunder Racing about there CAMS. The will get you the best cam for your needs.
1-877-516-7223
http://www.thunderracing.com/
There are better cams out there for your needs and the mods you have to get you the most HP. Just talk with them.
1-877-516-7223
http://texas-speed.com/shop/item.asp...d=666&catid=44
Around 10k miles, valvesprings didn't hold up well to the task and cracked one and dropped a valve. 6k dollars later, it was a very expensive lesson learned. I only want $250, tired of seeing it just sitting on my couch. I've got a FS thread if you want pictures. FYI I'd opt for the PRC platinums from TSP for peace of mind.
LS1 Tech Administrator
You saw my reply in the other section. Don't make the mistake of going too big on duration or lift. Low 230s, LSA around 111, lift around .600". Choose a lobe that will not give you valve control issues.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Hey man i really appreciate all your advice i would like to talk more with you on a camshaft that would best fit my needs...i have 3 cams in mind just wanted to pick your brain on the best choice.. could you give me a call when you get a chance? 817-542-2992 Bo
Lillian huh? What color is your car? Im always in that area since my car is being built over there. Oh and Ive had 2 ms3's, a trex, and now an EPS cam. What kind of stage II heads??
my car is black, where is your car being built?? main street custom maybe?? my heads are speedtek stage II little bigger valve (2.02 in) (1.575 ex) and a nice port and polish nothing to drastic..Im wanting a cam so Let me know what your wanting for an ms3 and what are the specs on the trex and eps?? thanks man look forward to seeing your car around!!!
