408 crank sensor problem HELP!!!
Old May 24, 2011 | 11:01 PM
JMAC's Avatar
Default 408 crank sensor problem HELP!!!
New motor with a 6.0 n 4'' stroke Eagle crank(24x). Car starts & runs but keep getting crank position not verified code. The idle air controller keeps closing all the way once car starts up, so it dies after running for a while. Tried another crank sensor same problem. At start timing is 23 degree, timing stays the same while idle but fuel goes crazy. All verified through H.P. Tuner software. Any help would be appreciated
Jerrymcalester@aol.com
214-601-6600
Old May 25, 2011 | 09:33 AM
DPRock's Avatar
pull it out and ill take the motor off your hands
Old May 25, 2011 | 09:40 AM
SSHAWK's Avatar
Sure give him $7k for it and it's yours.. lol
Old May 25, 2011 | 10:03 AM
DPRock's Avatar
only 7k i have that in my tool box wheres the motor
Old May 25, 2011 | 11:23 AM
built408's Avatar
What code it's setting? Are you actually loosing crank signal? Might just need a crank relearn..
Old May 25, 2011 | 12:05 PM
1SLwLS1's Avatar
My 408 did the same thing after the first fire up. I just replaced it and moved on.
Old May 25, 2011 | 12:29 PM
Bad Chad's Avatar
Check to make sure the wires are not burned or damaged from the headers.
Old May 25, 2011 | 12:38 PM
SSHAWK's Avatar
Been their done that on my car it sucks lol
Old May 25, 2011 | 12:56 PM
htownws6's Avatar
I hate to be the bearer of bad news but do you think there might be a possibility the reluctor wheel was installed backwards?
Old May 25, 2011 | 06:38 PM
JMAC's Avatar
Thanks to all for the help guys. I don't think Eagle would have place the reluctor wheel on backwards. Least I hope not, fingers crossed with that been said. Will run a crank relearn tomorrow evening to see if that helps, if not all good info is greatly appreciated.
Old May 25, 2011 | 06:47 PM
JMAC's Avatar
DPRock I sell you the whole car for $12500 or if its a big roller Snap On tool box, just leave the money ($7K) in it I'll just take box in all. You get new 408, turbo 400 (3800 Stall) QA1 front/rear with new wheels n tires. Don't be scarrrrred now.
Old May 26, 2011 | 01:52 AM
Sam88Gta1's Avatar
214-601-6600
If you were willing to wait I could fix this issue.
There is no one in the DFW area with more experience tuning SpeedDensity.
Old May 26, 2011 | 08:11 AM
SSHAWK's Avatar
x100
He's been wanting to take this car to the track for sometime now Sam.
You want to do a late night today to fix this?
Old May 26, 2011 | 07:24 PM
JMAC's Avatar
Thanks Sam, I've tried to call you today & came bye.
