LS7 427ci head choice....Trickflow 235cc vs. PRC 285cc?
What would be your choice of head for a 427 LS7 motor? I've been looking at the Trickflow 235cc heads which offer a really good midrange but seem to choke out above 6500rpm and I've been looking at the PRC 285cc head which seems to flow more like the LS7 heads with a fairly flat power band.
The cam is a 248/252 .660 110+3 cam that is in a basic forged piston LS7 motor with ARP hardware and a 24/28 ring gap for nitrous. Which head would you choose and why? The cost is similar ~$3000 for either set, but the PRC would include SS ex. valves and Ti. in. valves where the TFS heads have SS valves in both sides for that price. You can spend more to upgrade them, but for the sake of argument, lets not focus entirely on the money aspect. I don't want to spend $4-6k for a set of MAST or All-Pro's, just trying to find a good head setup for a basic head/cam pump gas Z06 that may end up on the bottle.
The other option of course is to stick with a set of ported WCCH LS7 heads. Currently I have a set of 13.8:1 WCCH high compression heads on E85, but I am selling them to go back to pump gas. Most people argue that it's not worth buying aftermarket heads for the LS7 since the stockers flow so well, but if I don't have a set of LS7 heads to work over, is it worth it to buy a set of LS7 heads and then work those over, or just go aftermarket and get the thicker .600 deck?
I was hoping for an unbiased view of the head options...so I wasn't sure if people had experience with the different head castings, port designs, torque curves, etc....just trying to see where the smart money would go. That way I can send my dumb money to the same place.
doesnt TFS also have a 245? Is this a street car? if so you arent going to really want to turn it past 7000. I have no personal experience with those specific castings though sorry
They do have a 245cc as well but it's a 6 bolt head. Not sure if I want to pay more for a 6 bolt head since I don't have a 6 bolt block. This is a street car, but it's a C6Z06 and my current shift point it around 7200 rpm. Obviously a different head setup may change my shift points and torque curve, but 7000rpm is currently right in the powerband.
The 285 prc is a ported Ls7 head. It will make good power but you will lose a little over the TFS head. You need to figure out if you want alot of low end or more top end. My 427 runs TFS 245 and made 570 rwhp locked up. Its a nitrous motor so if n/a it would easily be in the 600 range. Im using nitrous so i didnt need to spin it to the moon.
TT-TECH Veteran
I believe your mistaken on them only offering the 245 in a 6 bolt pattern its usually only a $100 option for the 6 bolt design. I ordered a set for the Powels in a 4 bolt design lol! And it says on there site offered in both 4 and 6 bolt designs. And I personally wouldn't go to a cathederal port over the LS7 stuff either! Just my opinion though! GL!
Jeff
I thought I read on their website that the 245cc was an LSX 6 bolt head.
When I went to the site this was the 3 different 245cc head option descriptions.
"Cylinder Heads, GenX® 245, Alum, Bare, 70cc CNC Chambers, 245cc Intake, Chevy LSX, CNC Ported, 6 Bolt, EA"
"LSX 245CC 6 BOLT/ .700 LIFT SPR"
"Cylinder Head, GenX® 245, CNC Ported, 6-Bolt Pattern, Aluminum, Assembled, 70cc CNC Chambers, Chevy,LSX, Each"
edit: Just went to TEA and they do come standard as a 4-bolt with the $100 upgrade for the 6-bolt. Thanks Jeff. Now to the question at hand.
So you would stick with the PRC or just stick with a set of ported LS7 heads from WCCH or similar? Why is that?
PRC 285s seem to flow really well and there was a guy here from Austin with those heads about a month ago and he was in the 650hp range on a nitrous tune with his LS7.
Seems like the bigger problem would be what intake to feed heads that flow close to
400, even a ported 102 would be holding flow of the heads back.
I also think resale value. if you ever were to change the, PRCs would bring back the most as well. I would put my money on the PRCs
TT-TECH Veteran
I was trying to keep the price down around $3000. I don't have any LS7 heads right now, so my option is to buy a set of LS7 heads and send them to WCCH or to buy a set of aftermarket heads. So technically the PRC heads would be the cheapest option for me. I keep debating nitrous, the motor was built for nitrous, so I may just do the 285cc just in case I spray the car.
I the the guybrunning the heads in austin is also high compression e85 car.
My buddy David Lazear is assembling me a 440 sleeved ls2 with PRC 285 heads to sell we have decided to get the REV hollow stem valves instead of TI. Were shooting for 600 rwhp on pump then a 300 on top of it. Like posted before the intake manifold will be the draw back.
I would get wcch ls7 heads with hollow stem intake valves. Then send aFast 102 to mamo and have him port match it and do his magic. I have seen it work well first hand.
LS1Tech Premium Sponsor
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
LS1 Tech Administrator
If you already have cathedral port intake manifolds, MAST has a really nice head with a 12 degree LS7 chamber and cathedral ports that's around $3000. It uses LS7 rockers and flows like the best of the high flow aftermarket LS7 heads. I've seen that head make 680rwhp on a 468 LSX with an ITB induction. Lots of new splayed valve and canted valve heads on the market now as well, but those are probably beyond the budget of this project.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
