Chevy needs to take tips from Ford
Fords interior is sexy and dodge isn't nothing to laugh at either. Oh I forgot to mention the 18% interest rate on a chevy.
That alone is enough to keep me away from them, I do my own work on my vehicles so that is a big consideration for me.
The last mod motor I worked on was in a newer F150, believe it was a 08 or 09. Truck came in for a tune up, and becuse the new spark plug design is so wonderful the spark plugs break off down in the cylinder head.
I also do a fair share of side work. I will do repairs on mod motors but I will not do timing chain or cyl head work on them. All makes have certain downfalls, but some far worse than others. Being experienced with so many different makes of vehicles in all area's of the vehicle is what made me buy a Chevy in the first place, ironically I used to think they were absolute junk. I drove Hondas and Acuras for many years before I bought my Camaro. And I tore down engines in those many times, far more difficult than an LS based motor but nothing like a mod motor.
I didn't buy a 4th gen F body Camaro because I am a blind brand loyalist.
2). The new fusion looks like an Aston Marton, they didn't invent anything
3). The new Escape looks like a monster truck version of the fiesta
that is all.
I am with codyvette, but maybe in a different sense. I am referring to engine teardown/repair. I have R&R'ed engine parts and cylinder heads on pretty much all the engines mentioned above plus many more. The cyl heads I had to R&R that I refuse to ever do again were on a Ford F150 with a 4.6, I later found out that the way the Ford tech's did it is to pull the cab of the truck off to save time. No thanks! I feel the same way about the Ford 4.0 V6 E motor. It has a damn timing chain between the transmission and engine for the bank one cylinder head. Rediculous...
i've had 1 or 2 4.6 liters apart. wasn't as bad as people think. i've never had a 5/4 apart, but for whatever reason, i've never liked those engines. maybe it's got to do with the ford spark plug thing. but then again, of the 5 or 6 of those spark plug repair kits i've installed, only 1 was below 200k miles. one of those was at 285k+ miles.
in my current situation at work, i don't do ANY engine jobs....meaning i won't r&r an engine. i farm those, and automatic transmission work out. i'll still do timing belts, timing chains, etc. i've got an escort lined up and a solara both getting timing belts right now.
when i used to do side work, i really didn't do much major work, unless i was stupidly slow. i always turned that down. i didn't want it, as it took up too much room for too long. i wanted stuff i could get in and out fast for decent money.
I agree, Ford has really came out with some awesome new idea's that need to be followed. And where I think they are really hitting the mark is all the turbo motors.
hudson was supercharging cars in the 50's. ford had DOHC engine in the 60's.....there were fwd in the 30's.
And on the spark plugs, I think you are referring to the problem they had with blowing the plugs out of the heads, that is not what I was talking about. They have a new spark plug that has a very long tip and uses a 14mm socket. When you remove them the tip breaks off and stays in the head. The rest of the plug with comes out in the socket.
