sad dyno results with h/c/I and bolts ons and tranny and yank 3600 stall
Old 05-27-2014, 09:23 PM
soloman369's Avatar
Default sad dyno results with h/c/I and bolts ons and tranny and yank 3600 stall
Hey guys idk what to think just got tuned last Friday (I was having a bad ground, so electrical issues. As in my previous thread ) I got 233/239 tsp cam, 799 PNP heads, 42# injectors and ls6 intake . These numbers seem really low to me . I wanted to know what yall think of the dyno sheet. I believe it was on dyno jet . But I have fix the bad ground today everything fine . But the car doesn't feel right tho, at higher speeds around 60 or 70 when I floor it it feels sluggish it doesn't really pick up and at 40 its OK at best. The tuner said that the electrical issue was causing the car to missfire . So I asked it was ok to tune he said yeah and he could still do it. I trusted him cause iv delt with him before . I just wanted to get some opinions. Thanks in advance guys .
Attached Thumbnails sad dyno results with h/c/I and bolts ons and tranny and yank 3600 stall-img_20140527_205943.jpg
Old 05-27-2014, 11:00 PM
5w20's Avatar
Who ported those heads and is the engine sound? More power to be had with it pulling higher but the torque looks low.
Old 05-27-2014, 11:31 PM
whatsa347's Avatar
What's wrong with the graph?0
Old 05-27-2014, 11:39 PM
soloman369's Avatar
A guy in la Porte PNP the 799 heads I'll get pic of them up in a few, really good job he did on them. Engines sound, its only at wot it feels sluggish. Yeah only gained like 23 in torque that's where I got worried a Little bit. But some ppl say dyno don't matter its how it feels. But unfortunately for me if feels sluggish. I wish he would just told me to fix the issue before he did the tune. But I trusted him. I thought the gagues not reading right was cause of the new heads and cam set up, since its my first one I didn't know what to expect. Car started fine and everything only when I actually started driving to get it tuned when the gagues fluxuated up and down etc, but it never turned off or any thing . I guess it was barley making ground.
Old 05-27-2014, 11:46 PM
soloman369's Avatar
Pics of heads
Attached Thumbnails sad dyno results with h/c/I and bolts ons and tranny and yank 3600 stall-wp_20140413_009.jpg   sad dyno results with h/c/I and bolts ons and tranny and yank 3600 stall-wp_20140413_015.jpg   sad dyno results with h/c/I and bolts ons and tranny and yank 3600 stall-wp_20140413_014.jpg   sad dyno results with h/c/I and bolts ons and tranny and yank 3600 stall-wp_20140413_003.jpg
Old 05-28-2014, 05:00 AM
In-Zane Moderator
ZONES89RS's Avatar
Put a carb on it and make magic. Lol
Old 05-28-2014, 07:43 AM
BoostJunkieXL's Avatar
What was the electrical issue that was causing it to misfire? I started my car one time and the battery was low, felt like it was only firing on every other cylinder. If the coils don't get full voltage, the won't fire correctly. I don't understand how he would say it will be fine to tune it when it's not firing on all cylinders. Get it fixed and take it to someone else.
Old 05-28-2014, 07:51 AM
Bad Chad's Avatar
^^^^ Why in the hell would any tuner try to tune a car knowing there is issues?
Try another wiring harness to see if that fixes your grounding issue.
I had a H/C/I car make 198rwhp on time, the owner was not happy with it so he bought a complete built motor. It made 204 with the now motor, come to find out it was a bad transmission that was holding the car back. Put a new trans in it and it ran like a champ...
Old 05-28-2014, 08:01 AM
cheeseLS2's Avatar
i can confirm i was that guy. shitty transmission lol
Old 05-28-2014, 09:10 AM
Bad Chad's Avatar
LOL, I did not want to say in names but holding the low RWHP built LS1 is something to be proud of LOL
Old 05-28-2014, 09:39 AM
soloman369's Avatar
I had a bad ground. There are three wires in the back of the driver side head. I only had two hooked up there are two thin ones and one thick one. Im guessing the third(thick one) that was loose and dangling was barley touching the block and making contact. So every time I hit a bump my gauges went crazy. So that's at every bump imagine at wot and with the engine loping and shaking at idle . It probably was making contact then not making contact making contact then not etc... causing it to miss. Well that my assumption.
Old 05-28-2014, 09:42 AM
soloman369's Avatar
Trans is fine. I believe it was just the bad ground. Like they say a bad ground is always 90% of a problem in electrical. It was making everything act weird well my gauges in my case.
Old 05-28-2014, 09:44 AM
soloman369's Avatar
Was your tanny not slipping, no signs? . How did you not know it was bad ?
Old 05-28-2014, 10:13 AM
Bad Chad's Avatar
The builder did not build it right. The car felt like something was holding it back as if the E-brake was on.
Old 05-28-2014, 10:18 AM
soloman369's Avatar
Ouch. Did the fluid smell burnt?
Old 05-28-2014, 10:45 AM
cheeseLS2's Avatar
imagine running underwater. thats how best describe it.
Old 05-28-2014, 10:51 AM
soloman369's Avatar
lmao dame. That bad huh. What you dyno after .
Old 05-28-2014, 11:57 AM
cheeseLS2's Avatar
490+ around that range
Old 05-28-2014, 02:37 PM
Trendkiller Z's Avatar
Just a random thought because I had this issue, but have you replaced the fuel filter lately or in between these mods?
Old 05-28-2014, 03:26 PM
soloman369's Avatar
Yes I replaced it the morning of the tune.
Quick Reply: sad dyno results with h/c/I and bolts ons and tranny and yank 3600 stall
